On ICX compiler getting the following while compile the following:
/#*#+ string +#/ \
test.c:10:5: error: pasting formed '/*', an invalid preprocessing token
HINT_PROC(Test);
test.c:5:5: note: expanded from macro 'HINT_PROC'
/##*##+ string *##/ \
test.c:10:5: error: pasting formed '*+', an invalid preprocessing token
test.c:5:8: note: expanded from macro 'HINT_PROC'
test.c:10:5: error: pasting formed '*/', an invalid preprocessing token
test.c:5:20: note: expanded from macro 'HINT_PROC'
3 errors generated.
After removing the line , the icx compiler is working fine
-On ICC for example getting only warnings:
test.c(10): warning #2358: concatenation with "*+" in macro "HINT_PROC" does not create a valid token
HINT_PROC(Test);
test.c(10): warning #2358: concatenation with "+" in macro "HINT_PROC" does not create a valid token
HINT_PROC(Test);
test.c(10): warning #2358: concatenation with "/" in macro "HINT_PROC" does not create a valid token
HINT_PROC(Test);
Any idea how to overcome this error issue?
Code for example is:
#include<stdio.h>
#include<string.h>
#define HINT_PROC(string)\
int main()
printf("Test\n");
HINT_PROC(Test);
return 0;
compiler version: 2020.1.1.217
ICC : 19.1.1.217 20200306
ICX: 2021.1 Beta 20200304
Thanks in advance
Moving this over to the C++ Forum. They can help you better.
