Dear all
i have a problem with ifort and icc and icpc. the compilers do not compiling anything. i tried to compile a sample fortran 90 and c program. but the following error is displayed on terminal
[muthu_mku@kalki ~]$ icc array.c -o array
icc: internal error: error generating temporary file name, check disk space and permissions (shared/driver/hostutil.c, line 853)
[muthu_mku@kalki ~]$ icpc array.c -o array
icpc: internal error: error generating temporary file name, check disk space and permissions (shared/driver/hostutil.c, line 853)
[muthu_mku@kalki ~]$ ifort for.f95 -o for
ifort: internal error: error generating temporary file name, check disk space and permissions (shared/driver/hostutil.c, line 853)
i compiled it on a cluster which has the following memory places
[muthu_mku@kalki ~]$ df -lh
Filesystem Size Used Avail Use% Mounted on
/dev/sda3 95G 71G 20G 79% /
/dev/sda6 92G 86G 925M 99% /export
/dev/sda5 48G 32G 14G 71% /opt
/dev/sda1 99M 63M 31M 68% /boot
tmpfs 16G 0 16G 0% /dev/shm
tmpfs 7.7G 37M 7.7G 1% /var/lib/ganglia/rrds
could anyone help me to resolve this problem. my compilers are in latest version
[muthu_mku@kalki ~]$ which icpc icc ifort
/opt/intel/Compiler/11.1/046/bin/intel64/icpc
/opt/intel/Compiler/11.1/046/bin/intel64/icc
/opt/intel/Compiler/11.1/046/bin/intel64/ifort
thank you very much
Check that you have permission to create and delete files in working directory and temporary directory, e.g.
pwd # do you own the directory where you are working?
touch junk
rm junk
echo $TMPDIR
touch $TMPDIR/junk
rm $TMPDIR/junk
