icc: error #10001: could not find directory in which g++ resides
Since g++ exists in my /usr/bin directory I assume that icc searches for g++ in different directories. I wonder if somebody knows the default directories which are scanned by icc or any commands which allow icc to find g++ in /usr/bin?
I would try these options:
-gcc-name=
name and location of gcc if not where expected
-gxx-name=
name and location of g++ if not where expected
Is /usr/bin in your PATH?
Judy
-gcc-name=
-gxx-name=
Judy
We can also try "-v" option.
$icc -v Hello.c
Thanks & Regards,
Sukruth.H.V
I'm not sure that asuggested option '-v' would help. Of course, you could try.
When that option is used with 'g++' it displays lots of details. Here is an example:
Reading specs from C:/WorkLib/MinGW342/Bin/../lib/gcc/mingw32/3.4.2/specs
Configured with: ../gcc/configure --with-gcc --with-gnu-ld --with-gnu-as --host=mingw32 --target=mingw32 --prefix=/m
ingw --enable-threads --disable-nls --enable-languages=c,c++,f77,ada,objc,java --disable-win32-registry --disable-sh
ared --enable-sjlj-exceptions --enable-libgcj --disable-java-awt --without-x --enable-java-gc=boehm --disable-libgcj
-debug --enable-interpreter --enable-hash-synchronization --enable-libstdcxx-debug
Thread model: win32
gcc version 3.4.2 (mingw-special)
C:/WorkLib/MinGW342/Bin/../libexec/gcc/mingw32/3.4.2/cc1plus.exe -quiet -v -iprefix C:\WorkLib\MinGW342\Bin/../lib/
gcc/mingw32/3.4.2/ -isystem ../../AppsSca/include -DNDEBUG MgwTestApp.cpp -quiet -dumpbase MgwTestApp.cpp -auxbase MgwTestApp -version -o C:\DOCUME~1\Admin\LOCALS~1\Temp/cc0Kaaaa.s
ignoring nonexistent directory "C:/WorkLib/MinGW342/Bin/../lib/gcc/mingw32/3.4.2/../../../../mingw32/include"
ignoring nonexistent directory "/mingw/include/c++/3.4.2"
ignoring nonexistent directory "/mingw/include/c++/3.4.2/mingw32"
ignoring nonexistent directory "/mingw/include/c++/3.4.2/backward"
ignoring nonexistent directory "/mingw/include"
ignoring nonexistent directory "/mingw/lib/gcc/mingw32/3.4.2/include"
ignoring nonexistent directory "/mingw/mingw32/include"
#include "..." search starts here:
#include <...> search starts here:
C:/WorkLib/MinGW342/Bin/../lib/gcc/mingw32/3.4.2/../../../../include/c++/3.4.2
C:/WorkLib/MinGW342/Bin/../lib/gcc/mingw32/3.4.2/../../../../include/c++/3.4.2/mingw32
C:/WorkLib/MinGW342/Bin/../lib/gcc/mingw32/3.4.2/../../../../include/c++/3.4.2/backward
C:/WorkLib/MinGW342/Bin/../lib/gcc/mingw32/3.4.2/include
End of search list.
GNU C++ version 3.4.2 (mingw-special) (mingw32)
compiled by GNU C version 3.4.2 (mingw-special).
GGC heuristics: --param ggc-min-expand=99 --param ggc-min-heapsize=130982
C:/WorkLib/MinGW342/Bin/../lib/gcc/mingw32/3.4.2/../../../../mingw32/bin/as.exe -o C:\DOCUME~1\Admin\LOCALS~1\Temp/
ccQlbaaa.o C:\DOCUME~1\Admin\LOCALS~1\Temp/cc0Kaaaa.s
C:/WorkLib/MinGW342/Bin/../libexec/gcc/mingw32/3.4.2/collect2.exe -Bdynamic -o Release\MgwTestApp.exe C:/WorkLib/Mi
nGW342/Bin/../lib/gcc/mingw32/3.4.2/../../../crt2.o C:/WorkLib/MinGW342/Bin/../lib/gcc/mingw32/3.4.2/crtbegin.o -L..
/../AppsSca -LC:/WorkLib/MinGW342/Bin/../lib/gcc/mingw32/3.4.2 -LC:/WorkLib/MinGW342/Bin/../lib/gcc -LC:/WorkLib/Min
GW342/Bin/../lib/gcc/mingw32/3.4.2/../../../../mingw32/lib -LC:/WorkLib/MinGW342/Bin/../lib/gcc/mingw32/3.4.2/../../
.. C:\DOCUME~1\Admin\LOCALS~1\Temp/ccQlbaaa.o -lstdc++ -lmingw32 -lgcc -lmoldname -lmingwex -lmsvcrt -luser32 -lkern
el32 -ladvapi32 -lshell32 -lmingw32 -lgcc -lmoldname -lmingwex -lmsvcrt C:/WorkLib/MinGW342/Bin/../lib/gcc/mingw32/3
.4.2/crtend.o
I think is just you have in /usr/bin gcc-x.x with g++-x.x
execute ls /usr/gcc* and ls /usr/g++* and make copy or link (ln) with that you have name with number version
on short name gcc and g++
Initially, g++ in /usr/bin was named g++-4.5 under openSUSE 11.4, which caused an early problem during installation, because the installation script searched for g++ only. So I renamed g++-4.5 into g++ which resulted in no more problems during installation. Obviously, this was not enough for the icc compiler which needs the additional option as mentioned above.
Many thanks also to the other contributors.
Roland
