I try to replace gcc with icc for a commertial product. Having tool compiled without ipo I get ~ same performance.
The onlOnce I set ipo tool starts crashing. I can't figure out code -> sigsegv relationship. It looks like this pointer within a method call is broken.
Valrgind reports several UMR and then ABW causes sigsegv.
Once I switch off ipo valgrind shows nothing.
Are there any guidelines to debug such case?
Alex
IPO definitely aggravates the effects of storing data outside defined regions. As you say, it doesn't necessarily improve performance.
Quoting - tim18
If you have a buffer overflow, it will have worse consequences with IPO set. RTFM is don't set IPO until your code is clean.
