Intel® C++ Compiler
7833 Discussions
Icc not detecting variables in task regions that are only used in (OMP) pragmas
Grund__Aalexander
Consider the following code:
#pragma omp parallel
#pragma omp single
#pragma omp task
        printf("%d\n", half_size); /* bug */
#pragma omp target data map(to:values[0:half_size])
#pragma omp target
#pragma omp parallel for
        for (i = 0; i < half_lists; ++i)
          sort(values, i, num_values);
Without the printf statement and any other usage of the variable, 'half_size' within the target pragma is not recognized by the compiler as required within the 'omp task' block. In contrast, 'half_lists' and 'num_values' are properly copied as they are used in user code and not solely in a target pragma.
Thus, once the runtime hits 'omp target data map', half_size is not properly set, resulting in offload errors, e.g.
'offload error: address range partially overlaps with existing allocation'.
Tested with composer_xe_2013_sp1.2.144 (icc 14.0.2)
MalReddy_Y_Intel
Could you please help us with a complete (compilable) test code to reproduce the error?
Reddy
Grund__Aalexander
One example code is this:
#include <stdio.h>
#include <stdlib.h>
int main (int argc, char *argv[]) {
  int half_size = 1000;
  int* values = (int*) malloc(sizeof(int)*half_size);
  int i;
    #pragma omp single
      #pragma omp task
        #pragma omp target
          for (i = 0; i < half_size; ++i)
            values = i;
  return EXIT_SUCCESS;
If you try to run this, you get a segFault on the device. If you comment the #pragma omp task (note, that this does not change anything in this case) the example works.
I also got the error mentioned in the first post but I cannot reproduce it with a small sample. Will try and update as soon as I got something.
Sukruth_H_Intel
Hi, I was able to reproduce both the errors that you have mentioned above and also escalated the same to our eng team, I would get back to you with an update. #include #include int main (int argc, char *argv[]) { int half_size = 1008; int* values = (int*) _mm_malloc(sizeof(int)*half_size,64); int i; #pragma omp parallel { #pragma omp single { #pragma omp task { #pragma omp target data map(tofrom:values[0:half_size]) #pragma omp target #pragma omp parallel for #pragma vector aligned for (i = 0; i < 100; ++i) values = i; } } } return EXIT_SUCCESS; } Regards, Sukruth H V
