Hi all,
I'm compiling this tool called XIOS for parallel I/O operations,
When i compile it with all its dependencies (HDF5, Netcdf) , and running the test, I get the following error:
forrtl: severe (168): Program Exception - illegal instruction Image PC Routine Line Source xios_server.exe 0000000000A69351 Unknown Unknown Unknown xios_server.exe 0000000000A6748B Unknown Unknown Unknown xios_server.exe 0000000000A145D4 Unknown Unknown Unknown xios_server.exe 0000000000A143E6 Unknown Unknown Unknown xios_server.exe 00000000009EDC69 Unknown Unknown Unknown xios_server.exe 00000000009F14C4 Unknown Unknown Unknown libpthread-2.12.s 000000370640F710 Unknown Unknown Unknown xios_server.exe 0000000000A74F58 Unknown Unknown Unknown xios_server.exe 0000000000830547 Unknown Unknown Unknown xios_server.exe 00000000007A1B93 Unknown Unknown Unknown xios_server.exe 00000000007A1D8A Unknown Unknown Unknown xios_server.exe 00000000007A892F Unknown Unknown Unknown xios_server.exe 000000000074BB6D Unknown Unknown Unknown xios_server.exe 0000000000700646 Unknown Unknown Unknown xios_server.exe 000000000070152D Unknown Unknown Unknown xios_server.exe 000000000067011F Unknown Unknown Unknown xios_server.exe 0000000000640B95 Unknown Unknown Unknown xios_server.exe 000000000063E464 _ZN4xios9CONetCDF 15 onetcdf4.cpp xios_server.exe 00000000005A705C _ZN4xios14CNc4Dat 31 nc4_data_output.cpp xios_server.exe 00000000005A7001 _ZN4xios14CNc4Dat 28 nc4_data_output.cpp xios_server.exe 0000000000527469 _ZN4xios5CFile12c 297 file.cpp xios_server.exe 0000000000526A9D _ZN4xios5CFile9ch 180 file.cpp xios_server.exe 000000000051A266 _ZN4xios6CField10 192 field.cpp xios_server.exe 000000000051A032 _ZN4xios6CField14 182 field.cpp xios_server.exe 0000000000519449 _ZN4xios6CField14 139 field.cpp xios_server.exe 0000000000519159 _ZN4xios6CField13 84 field.cpp xios_server.exe 00000000004E94FF _ZN4xios14CContex 196 context_server.cpp xios_server.exe 00000000004E9277 _ZN4xios14CContex 155 context_server.cpp xios_server.exe 00000000004E857F _ZN4xios14CContex 50 context_server.cpp xios_server.exe 00000000006433F9 _ZN4xios7CServer1 379 server.cpp xios_server.exe 000000000064326B _ZN4xios7CServer9 161 server.cpp xios_server.exe 0000000000644DF7 _ZN4xios7CServer1 126 server.cpp xios_server.exe 00000000004EB390 _ZN4xios5CXios14i 72 cxios.cpp xios_server.exe 000000000040CA2C MAIN__ 7 xios_server.f90 xios_server.exe 0000000000A1E7C2 Unknown Unknown Unknown libc-2.12.so 0000003705C1ED5D __libc_start_main Unknown Unknown xios_server.exe 000000000040C929 Unknown Unknown Unknown
My operating system is Centos 6.6. The login node in which I'm compiling its: a
Intel(R) Xeon(R) CPU X5675 @ 3.07GHz
The compute nodes are:
Intel(R) Xeon(R) CPU E5472 @ 3.00GHz flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_good aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm dca sse4_1 lahf_lm dts tpr_shadow vnmi flexpriority
I'm compiling all the dependencies with the following directives:
-O3 -xSSE4.1 -fp-model source
I'd like to know if there is anything wrong with my setup , i'll appreciate it.
This code used to work with an older version of the intel compilers,
FavioMJ
Thanks for the reply,
I was able to run this code, by compiling all its dependencies with the following options:
-O3 -msse4.1
The thing is that the login node has a newer processor than the compute nodes, and some of the flags are not available in the compute nodes. Still there is something wrong numerically but i'm looking..
