Intel® C++ Compiler
7833 Discussions
Implicit conversions for std::complex
Dewing__Mark
Passing a std::complex<float> constant to a function that takes a std::complex<double> argument receives the wrong real part inside the function.    Passing a std::complex variable produces the expected result.   Changing the function to accept a value rather than a const reference makes no difference.
#include <complex>
#include <iostream>
void f(const std::complex<double> &val)   // or void f(std::complex<double> val)
    std::cout << "In f1, val = " << val << std::endl;
int main()
    f(std::complex<float>(1,2));   // Fails
    std::complex<float> b(1,2);
    f(b);  // Works
    return 0;
Produces the output:
In f1, val = (2,2)
In f1, val = (1,2)
This is with the Intel compiler 19.0.4.243.    GCC and clang give the expected results.
Viet_H_Intel
Thanks for reporting this issue. I've submitted a bug #CMPLRIL0-32033 to the compiler Developer.
