The following code can be compiled by g++ but not icpc.
Any idea to solve this issue without modifying the code?
my g++ and icpc version info:
$ g++ -v
Using built-in specs.
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk --disable-dssi --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-1.5.0.0/jre --enable-libgcj-multifile --enable-java-maintainer-mode --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --disable-libjava-multilib --with-ppl --with-cloog --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux
Thread model: posix
gcc version 4.4.7 20120313 (Red Hat 4.4.7-3) (GCC)
$ icpc -v
icpc version 13.0.1 (gcc version 4.4.7 compatibility)
#include <iostream>
template<bool B> class CompileTimeAssert { };
template<> class CompileTimeAssert<true> {
public:
static inline void Check() { }
#define COMPILE_TIME_ASSERT(b) CompileTimeAssert<(b)>::Check()
int main()
COMPILE_TIME_ASSERT(true && "err msg");
std::cout<<(true && "err msg")<<std::endl;
return 0;
For icpc, here is the error message.
$ icpc a.cpp -o a
a.cpp(13): error: non-integral operation not allowed in nontype template argument
a.cpp(13): error: class "CompileTimeAssert<<error-constant>>" has no member "Check"
compilation aborted for a.cpp (code 2)
i don't think it is. the code can be compiled by this cmd line
g++ -std=c++98 a.cpp -o a
You will note, in accordance with Sergey's hint, that icpc has no trouble with your example when you set -std=c++11 and have a g++ on path which supports that option. Apparently, this is another c++11 feature which was supported by g++ outside of the option but is not inherited by icpc in that mode.
icpc 13.0.1 with -std=c++0x option also fails.
$ icpc -std=c++11 a.cpp
I would not expect a new backward compatibility fix when icpc working of -std=c++11 has been supported on top of g++ 4.7 and newer for some time. You're certainly entitled to file a question using your premier.intel.com support account if you have reasons for wanting this compatibility or hope to get an explanation of the reasoning for requiring a more up to date g++. I would guess that it didn't make sense to attempt to support minor bits of c++11 with interfaces which no longer exist in current g++.
I agree that it looks like a gap in claimed compatibility with RHEL. As noted in another thread, claimed compatibility with older Fedora versions which aren't updated to g++ 4.7 has been dropped.
