icc 15.0 gives me a warning when compiling the following code:
template
using type alignas(64) = T;
warning #3463: alignas does not apply here
If I understand correctly my code is correct, and indeed GCC and Clang compile it properly without warnings. Is this a known issue with icc? Can I expect a fix in future versions?
Simon
Hi Simon,
Could you please attach the testcase which generates this warning.
Thanks and Regards
Anoop
Sorry, the forum seems to have swallowed the template brackets in my first post, put this in test.cc:
template <class T> using type alignas(64) = T; type<int> x;
Compile with
icpc -std=c++0x -c test.cc
Thank you this has already been reported in this topic here:
https://software.intel.com/en-us/forums/topic/531592
Topic Options
