Intel® C++ Compiler
7956 Discussions
Incomplete C++11 "alignas" implementation
Simon_H_2
Hi, icc 15.0 gives me a warning when compiling the following code: template using type alignas(64) = T; warning #3463: alignas does not apply here using type alignas(64) = T; If I understand correctly my code is correct, and indeed GCC and Clang compile it properly without warnings. Is this a known issue with icc? Can I expect a fix in future versions? Thanks, Simon
Anoop_M_Intel
Hi Simon,
Could you please attach the testcase which generates this warning.
Thanks and Regards
Anoop
Simon_H_2
Sorry, the forum seems to have swallowed the template brackets in my first post, put this in test.cc:
template <class T>
type<int> x;
Compile with
icpc -std=c++0x -c test.cc
Judith_W_Intel
Thank you this has already been reported in this topic here:
https://software.intel.com/en-us/forums/topic/531592
