Intel® C++ Compiler
7838 Discussions
Incorrect resolution of class in anonymous namespace
Andrew_Smith1
Hii
We came across an issue in our Intel (2016) compiler build where it appears separate, but identically named, classes in anonymous namespaces are not being resolved correctly. We've managed to create small example that illustrates the problem, and wondered if somebody could please investigate.
In the attached source you can see two definitions of class Local within anaonymous namespaces in separate translation units (case1.cpp and case2.cpp). What appears to be happening is that the two objects are not being resolved correctly, and in this case a segmentation fault ensues when the object is accessed.
Compare the output from g++ (4.9):
We are in case1
instance(): N12_GLOBAL__N_15LocalE sized as 8
getThreadLocalInstance(): current N12_GLOBAL__N_15LocalE sized as 8 @ 0
getThreadLocalInstance(): new N12_GLOBAL__N_15LocalE sized as 8 @ 0x1cad7010
We are in case2
getThreadLocalInstance(): new N12_GLOBAL__N_15LocalE sized as 8 @ 0x1cad7080
We are in case1
getThreadLocalInstance(): current N12_GLOBAL__N_15LocalE sized as 8 @ 0x1cad7010
myA=XXX
We are in case2
getThreadLocalInstance(): current N12_GLOBAL__N_15LocalE sized as 8 @ 0x1cad7080
myA=1234567
and that from icpc:
We are in case1
getThreadLocalInstance(): new N12_GLOBAL__N_15LocalE sized as 8 @ 0x6d59010
We are in case2
getThreadLocalInstance(): current N12_GLOBAL__N_15LocalE sized as 8 @ 0x6d59010
We are in case1
Segmentation fault
In the latter you will see that both the case1 and case2 objects are at the same address, and then we get a segfault, according to gdb, on attempting to print the member variable (at case1.cpp:26)
To build this example just run "make CXX=icpc" and/or "make CXX=g++"
Andrew
PS Just noticed the issue has already been raised here: https://software.intel.com/en-us/forums/intel-c-compiler/topic/597089
Judith_W_Intel
The bug report mentioned in the other thread (DPD200377293) was fixed on 11/23 and I tried you test case and it appears to have fixed this too. So the next 16.0 update (update 2) should contain the fix. Sorry for the inconvenience.
This is what I see with the current 16.0 development compiler:
sptel37-33> make "CXX=icc49"
icc49 -g -std=c++11   -c -o case1.o case1.cpp
icc49 -g -std=c++11   -c -o case2.o case2.cpp
icc49 -g -std=c++11   -c -o main.o main.cpp
icc49 case1.o case2.o main.o -o example
sptel37-34> ./example
We are in case1
getThreadLocalInstance(): new N12_GLOBAL__N_15LocalE sized as 8 @ 0xd79010
We are in case2
getThreadLocalInstance(): new N12_GLOBAL__N_15LocalE sized as 8 @ 0xd79080
We are in case1
getThreadLocalInstance(): current N12_GLOBAL__N_15LocalE sized as 8 @ 0xd79010
myA=XXX
We are in case2
getThreadLocalInstance(): current N12_GLOBAL__N_15LocalE sized as 8 @ 0xd79080
myA=1234567
sptel37-35>
Kittur_G_Intel
I agree, thanks Judy.  As soon as the release (16.0 update 2) is out, I'll update the thread here, fyi.
_Kittur
Kittur_G_Intel
Hi Andrew,
This issue is fixed in the latest 16.0 update 2 release which you can download from the Intel registration center and test it out, thanks.
Kittur
