Intel® C++ Compiler
7873 Discussions
Incremental compilation not working
dnesteruk
I have a VS2013 solution with a couple of CPP/H files as well as a precompiled header which contains a lot: it has references to Boost, Intel libraries and more. My precompiled header is set up correctly on all files: it's set to Create on stdafx and Use on other files.
Now the problem I have is that, every time I go to Build Project, the entire thing gets built, using the precompiled header and all. This is not right, because stdafx.cpp should only be built once. And this problem is Parallel-XE-specific because Microsoft does it correctly.
Shenghong_G_Intel
You may take a look at below link regarding the differences of Intel compiler precompiled header support and see whether you hit one the cases.
https://software.intel.com/en-us/node/522754
Shenghong
dnesteruk
Shenghong
Umm, no, I'm not hitting any of these cases and my problem is more fundamental: not so much with the generation of PCH but the fact it gets regenerated on every compile, even if I change a single symbol in one of the CPP files. This shouldn't be happening.
Feilong_H_Intel
Hi dnesteruk,
Are you able to create a smaller test case (solution) that demostrates the problem?  We need something to reproduce it on our machine and then investigate.
