I've encountered a wierd problem. When I was doing:
double p[]={1.d, 2.d, 3.d, 4.d, 5.d};//or even double p[5] = blahblahblah...
And then I made a for loop to check the values of array p, I got all zeros. This is a problem that I abstract during the debugging. In fact, this happens when I use icc or icpc to compile, on the contrary, the it truns out that everything is fine with gcc or g++. I'm so confused...
I'm using icc version 13.1.0.
Thank you for your comments!
As far as I know, a "d" suffix is not standard for floats. Use one of:
- "f" or "F" for "float"
- "l" or "L" for "long double"
- (nothing) for "double"
This must be GCC's extension to the standard.
changing ".d" to ".f" does work around the issue.
Not sure since which version of gcc that accepts the ".d". But I'll file a ticket for it.
Jennifer
Topic Options
