Community
cancel
Showing results for
Search instead for
Did you mean:
Frank_V_Intel
Inline assembler jump through eBX
I'm trying to compile the following code, and I keep getting a warning indicating the compiler is expecting an indirect jump, but I want the direct form of the jump.  How do I trick the compiler into doing what I want?  The specific warning is "/usr/tmp/iccuUW8dVas_.s:59: Warning: indirect jmp without `*'", and if I add the indirect construction, the compiler is happy, but the code goes into the weeds.
    asm (
        "movl    $0xfff06278, %%ebx\n"
        "jmp     %%ebx\n"
        ::: "ebx"
