Hi
When I run icc 12.0.2 on my MAC OSX then I get
eda@gentofte:~$ icc
No enough memory when malloc -1 bytes at shared/flexlm/api/flexlm.c:6788
Abort trap
Things works fine if I am root but not if I am ordinary user.
Any suggestions.
Erling
eda@gentofte:~$ icc
Abort trap
Any suggestions.
Erling
Your environment seems corrupted.
If you have booted 64bit version of OS and installed the Intel compiler in default location then you need to run the following:
$ source /opt/intel/composerxe/bin/compilervars.sh intel64
$ icc -V
Intel C Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.2.142 Build 20110112
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
I have used the following to try out the compiler:
$ cat tstcase.cpp
#include
int main()
printf("Hello world.\n");
return 0;
$ icc tstcase.cpp
ld: warning: -macosx_version_min not specificed, assuming 10.6
$ ./a.out
Hello world.
