I fail the installation of parallel Studio XE 2016 in my mac pro including OS X* 10.10.5 and Xcode 7.0.
How can I install it successfully?
I tried the click to dmg file ==> no response
$ sudo ./install_gui
=> no response
$ sudo ./install.sh
./install.sh: line 616: 6866 Segmentation fault: 11 "$pset_engine_binary" --TEMP_FOLDER="$temp_folder" $params $root_nonroot 2> /dev/null
We're aware of this issue and is being investigated and will update you as soon as I've an update from the team. Appreciate your patience till then, thanks much.
_kittur
Hi Eun ae,
Again, just letting you know that we appreciate your patience through this issue as the next update 1 will have a fix for this issue which should be out this month. Unfortunately there's no workaround available other than waiting for the update. Pardon the delay and appreciate your understanding through this.
_Regards,
Kittur
