Intel® C++ Compiler
7779 Discussions
Install failures on C++ Composer for Linux
Dave_A__from_Lifeboa
Customer writes:
It goes through the install and simply goes fail fail fail....etc with no reason or log file
that I can see.
My last attempt had a java error, which supposedly got resolved with a java install.
[root@ls00063p ~]# yum install java
[.... snip ...]
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
Installing : jpackage-utils 1/3
Installing : tzdata-java 2/3
Installing : java-1.6.0-openjdk 3/3
Installed:
java-1.6.0-openjdk.x86_64 1:1.6.0.0-1.16.b17.el5
Dependency Installed:
jpackage-utils.noarch 0:1.7.3-1jpp.2.el5 tzdata-java.x86_64 0:2010l-1.el5
Complete!
[root@ls00063p ~]# which java
/usr/bin/java
My 2nd last attempt is captured here.
There is one or more optional unresolved issues. It is highly recommended to fix
it all before you continue the installation. You can fix it without exiting from
the installation and re-check. Or you can quit from the installation, fix it and
run the installation again.
Missing optional pre-requisites
-- No compatible Java* Runtime Environment (JRE) found
1. Skip missing optional pre-requisites [default]
2. Show the detailed info about issue(s)
3. Re-check the pre-requisites
h. Help
b. Back to the previous menu
q. Quit
Please type a selection or press "Enter" to accept default choice [1]: 1
After trying...
Each component will be installed individually. If you cancel the installation,
components that have been completely installed will remain on your system. This
installation may take several minutes, depending on your system and the options
you selected.
Installing Intel C++ Compiler XE 12.1 Update 1 on IA-32 component... failed
Installing Intel C++ Compiler XE 12.1 Update 1 on Intel 64 component... failed
Installing Intel Debugger 12.1 Update 1 on IA-32 component... failed
Installing Intel Debugger 12.1 Update 1 on Intel 64 component... failed
Installing Intel Math Kernel Library 10.3 Update 7 on IA-32 component... failed
Installing Intel Math Kernel Library 10.3 Update 7 on Intel 64 component... failed
Installing Intel Integrated Performance Primitives 7.0 Update 5 on IA-32
component... failed
Installing Intel Integrated Performance Primitives 7.0 Update 5 on Intel 64
component... failed
Installing Intel Threading Building Blocks 4.0 Update 1 core files and examples
component... failed
Press "Enter" key to continue
**** When I hit enter I get:
q. Quit [default]
Please type a selection or press "Enter" to accept default choice :
Thanks for the help.
Dave A. from Lifeboat Distribution.
Om_S_Intel
Could you please help me with architecuture, OS version,GNU gcc version and Intel Composer XE 20011 package ID? It would be nice if you could submit the issue to http://premier.intel.com.
TimP
Black Belt
Certain linux distros (including a few which should have been "supported") came with a preset symlink to gcj set in /usr/bin/java. If you tried
java -version
or
ls -l /usr/bin/jav*
you would see that this was not a symlink to Sun JRE or a clone.
The Intel debugger installation did not work unless you first removed that symlink.
After further questioning see below:
1. What version operating system are they trying to install on, what manufacturer?
*** redhat 5.6
2. What machine type are they loading it on?
Linux os, with a filerbackend. The linux box is a 64-bit machine
Linux ls00063p.encana.com 2.6.18-194.17.1.el5 #1 SMP Mon Sep 20 07:12:06 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux
3. Are they using Intel Flexlm license manager
*** We haven't got there yet. Hopefully will run on flex 10.8 or greater
4. What other errors are they getting ?
During install (./install.sh as root ) I got a needs g++ error.
We installed g++ and restarted. -> yum install gcc-c++
We then got a
so we installedjava-1.6.0-openjdk.x86_64 1:1.6.0.0-1.16.b17.el5 (yum install java )
on the local box.
Then the install seemed to think it was good to start. but...
we got failures on each module.
I am going to do a fresh start starting with tar -xzvf 1_ccompxe_2011.7.256.tgz
One note: we don't run the internet on the linux box, so I downloaded it to a windows box and
moved it to the linux box. Same with the license. Which I then ran dos2unix against the license file.
Hope that helps.
