Intel® C++ Compiler
Installation error
marco_v
I've installed Intel Compiler Suite for 64bit Linux (wich includes, the compiler, mkl, etc).
I'm running a CentOS 5.
But when i try to use the icc compiler, I get this error
/opt/intel/Compiler/11.1/072/bin/intel64/icc -o a a.c
/opt/intel/Compiler/11.1/072/bin/intel64/mcpcom: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
compilation aborted for a.c (code 127)
and this is a.c
#include
#include
int main (int argc, char *argv[])
printf("test");
Do you any ideas of what might be causing this error?
Also, I already have both 64bit and 32bit installed:
yum install libstdc++
Package libstdc++-4.1.2-46.el5_4.2.x86_64 already installed and latest version
Package libstdc++-4.1.2-46.el5_4.2.i386 already installed and latest version
Thank you,
Marco
marco_v
Solved the problem with the following command:
"yum install compat-libstdc++-33"
I had only -33-3.2.3-61.i386 .
I had to install the x86_64as well.
Thank you,
Marco
