Intel® C++ Compiler
7932 Discussions
Instruction behavior description in intrinsics like pseudo code
Rot
Is there any resource which maps all kinds of x86 instructions to "parsable" pseudo code?
The intrinsics guide has a very clean representation of each intrinsic behavior under Operation.
But I can not find something similar for simple x86 instructions and its extensions.
The instructions pseudo code in the IA-32 manual (SDM Volume 2) is really vague sometimes.
Is there any such resource for asm instruction behavior which matches the clean syntax of the intrinsic behavior?
MadhuK_Intel
Thank you for posting in Intel communities.
>>” maps all kinds of x86 instructions to "parsable" pseudo code?
Could you please elaborate on what do you mean by the “parsable” pseudo code?
>> ”The instructions pseudo code in the IA-32 manual (SDM Volume 2) is really vague sometimes.”.
Could you please confirm whether this is the document you are referring to? https://cdrdv2.intel.com/v1/dl/getContent/671200
Could you please let us know the particular intrinsic or instruction that you wanted to know about it? Or you can find the particular intrinsic information and its pseudocode by searching at the top of the intrinsics guide.
Madhu
Rot
Hi Madhu!
Thank you for your reply.
Yes indeed. That's the one.
I think about how to uplift the x86 instructions to the intermediate language RZIL. One way to uplift so many instructions would be to take the behavior of each single instruction (written in something C like) and compile it into the intermediate language.
To make this possible the compiler/parser would need a mostly well defined language the instruction behavior is written in.
Here an example:
The PUSHA instruction behavior in the manual looks like this:
IF 64-bit Mode
   THEN #UD
FI;
IF OperandSize = 32 (* PUSHAD instruction *)
  THEN
    Temp := (ESP);
    Push(EAX);
    Push(ECX);
    Push(EDX);
    Push(EBX);
    Push(Temp);
    Push(EBP);
    Push(ESI);
    Push(EDI);
  ELSE (* OperandSize = 16, PUSHA instruction *)
    Temp := (SP);
    Push(AX);
    Push(CX);
    Push(DX);
Syntax like "IF 64-bit Mode" makes it really hard to parse and compile this instruction behavior into an intermediate language.
Another example would be the MASKMOVDQU instruction:
The behavior in the manual is:
IF (MASK[7] = 1)
   THEN DEST[DI/EDI] := SRC[7:0] ELSE (* Memory location unchanged *); FI;
IF (MASK[15] = 1)
   THEN DEST[DI/EDI +1] := SRC[15:8] ELSE (* Memory location unchanged *); FI;
   (* Repeat operation for 3rd through 14th bytes in source operand *)
IF (MASK[127] = 1)
   THEN DEST[DI/EDI +15] := SRC[127:120] ELSE (* Memory location unchanged *); FI;
The corresponding intrinsic "void _mm_maskmoveu_si128(__m128i d, __m128i n, char * p)" is:
FOR j := 0 to 15
	i := j*8
	IF mask[i+7]
		MEM[mem_addr+i+7:mem_addr+i] := a[i+7:i]
	FI
ENDFOR
The latter one could be easily parsed and compiled into the intermediate language. The former not so easily.
MadhuK_Intel
Sorry for the inconvenience caused, there are no references available other than Intel® Intrinsics Guide and Intel® 64 and IA-32 Architectures Software Developer Manuals which we have mentioned already in the previous posts.
Thanks and regards,
Madhu
MadhuK_Intel
We have not heard back from you. Could you please provide an update on your issue? Can we go ahead and close this thread?
Madhu
MadhuK_Intel
As we haven't heard back from you, we assume that you got the required information from us and closing this thread. Please post a new question if you need any additional information from Intel, as this thread will no longer be monitored.
Thanks and regards,
Madhu
