I'm trying to integrate Intel composer c++ with eclipse. I know that this point has already been the subject of several other posts but my problem is that in the composerxe I can't find any sub directories eclipse_support type with what follows. Not a big deal because I can use the xcode IDE or the terminal but I'nervus when I'cant resolve a problem specially if it is a stupid problem.
Help please
Giorgio
You mention Xcode, so I assume you're using a Mac. We provide the Eclipse integration for Intel C++ on Linux only.
Thanks if it is transferable on mac interests me a lot.
Giorgio
Hai Sergey!
It also works with the Mac. I'm still not able to locate exactly the full path of the compiler. I have entered this path/opt/intel/composer_xe_2013.5.1981/bin/intel64
When I go to add new software I find exactly the position of the path where but misses the compiler.
I'll tray
Giorgio
