I had to switch from Win XP 32Bit to Win 7 64 Bit.
Now, I have a problem with the integration of the Compiler V10.0.025 into VS 2005 on the Win 7 64 bit system.
There is an error message Compiler Integration Package... has failed to load properly
GUID = {D6EEEC80-45EA-4CA7-AE30-747000CA09F81}.
vcvarsall.bat does work.
Maybe there is some help,
Thank you.
Can you post log file and not message excerpt?
Remember the additional steps involved in installing VS2005 on Win7: Vista/Win7 patch and subsequent service packs. After selecting C++ support option you need the sub-option for X64 support, all of this before you open up the Intel compiler installer. Significant mistakes require removing and starting over. You must be in administrator mode all the time, both installing and using.
Unfortunately the info which you provided is not very helpful.I would advise you maybe to search %temp% folder for any log files.
