Intel® C++ Compiler
Integration with VS 2010
aurora
I'm having problems with the Composer XE 12.1 compilers integration with VS2010 SP1. The problem I've already reported in microsoft VS forum with a screenshot:
"In others versions of VS (2008), I can show the properties page of a single file, in order -for example- to change the compiler options for only that file. With VS2010 SP1, I cant do this, because the whole window is empty . Why is this happening?"
Is this a known bug?
Thanks in advance!
Om_S_Intel
The Visual Studio 2010 SP1 and Intel C++ Composer XE 12.1integration works as expected for me. I can change the setting for single file using the property page.
Om
aurora
I have exactly the same problem in two computers.
The versions numbers are:
Intel C++ Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.1.070 Build 20110811
VS: 10.0.40219.1 SP1
aurora
I send you also a simple solution when this issue happens to me
