Is Intel compiler able to integrate with Visual C++ 2010 express? I am still using the Intel Compiler 9.1 version, if not, is there a way to manually configure it?
VC express doesn't allow GUI integration for any non-Microsoft compilers. I haven't heard of any change with 2010. It may work for 32-bit command line operation only, if you make the necessary edits in iclvars.bat and icl.cfg. ICL 9.1 wasn't tested for VS2008, let alone VS2010, so you may find advantages in a newer ICL (12.0 for VS2010, should be released in about 3 months).
Intel C++ Compiler 12.0 which is part of Intel Parallel Studio 2011 and Intel Parallel Composer packages does support Visual Studio 2010 but **not** the Express Edition.
--mark
--mark
Topic Options
