is -O3 already expected to build correct code?
I found the page from 2009:
http://software.intel.com/en-us/articles/use-intel-compilers-successfully-for-6
"Using -O3, the compiler performs aggressive optimizations, and the
optimizer occasionally generates incorrect code."
We found another example for a misoptimisation.
(Attached is the sample Application.)
Compile the sample Application :
icpc -O3 test.cpp -o test
run it:
/test
dxx[0] = 2.885465e+01
Now exchange line 115 with line 116:
compile:
run:
./test
dxx[0] = 0.000000e+00
The problem goes away when building with -O2 or using
Intel 11.1 compiler.
So, if O3 should work, this is a bug. Otherwise this sample App
can be use to fix the problem.
regards,
Martin
run it:
/test
compile:
run:
./test
regards,
Martin
Here is the complete link to the Intel article quoted above:
Intel article
The optimization bug reported above is not seen with the 12.0.4 compiler on Windows (32 and 64 bit).
Intel article
I get same output when I swap lines 115 and 116 using icc12.0.4.191. Please upgrade your compiler.
