I met an error when I try to compile my code. The error is:
": internal error: ** The compiler has encountered an unexpected problem.
** Segmentation violation signal raised. **
Access violation or stack overflow. Please contact Intel Support for assistance.
compilation aborted for a.cpp (code 4)
This is the command I used:
icpc -qopenmp -g -o a.cpp.o -c a.cpp
icpc --version
icpc (ICC) 19.1.0.166 20191121
Copyright (C) 1985-2019 Intel Corporation. All rights reserved.
Here is my code of a.cpp:
namespace AAAA {
void setP(int n) {
return;
class TEST {
public:
void f();
void TEST::f(){
int i, n = 0;
int* pts[8];
#pragma omp parallel for default (shared) private(i, pts)
for(i=0;i<10000;i++)
#pragma omp critical
try{ setP(n);}
catch (...){
This is another crash situation. This one happens on windows 64 bit with visual studio 2019 and Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.0.166 Build 20191121.
The command is:
"C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" /c /Qm64 /nologo /W3 /MP /O2 /Ob2 /D NDEBUG /D _WINDLL /D _MBCS /EHsc /MD /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Fo"Release\\" /Fd"Release\vc142.pdb" /TP -Qopenmp intel_window_fail.cpp
Could you please try using icpx compiler instead of icpc compiler
Meanwhile we will look into this issue internally. we will get back to you soon.
Vidya.
On Intel compiler 2020.0.166, icpx works. But if I use 2020.4.304, it failed with:
clang++: error: unsupported option '-qopenmp'.
Can you add either -O1, -O2 or -O3 as a workaround for Linux case and use /Od for Windows case?
Not sure if you removed /O2 and /Ob2 on Windows.
and icx.exe should work for your Windows case too.
Yes, something is wrong with that version. Can you use other versions?
$ icpx -fopenmp -g -c a.cpp
$ icpx -qopenmp -g -c a.cpp
Can you confirm icpx worked for your case? We would like to close this thread if icpx compiles it.
Please let us know if icpx works for you. We would like to close this thread.
Not sure if you already knew, but Intel Classic Compiler will enter "Legacy Product Support" mode, signaling the end of regular updates. Please refer to the article bellow for more details.
For that reason, Developer isn't plan to to fix this in Classic compiler. Can you migrate to icx/icpx?
We are going to close this case. If you have any questions/concerns, please create a new thread.
Viet
