Hello there :)
We are using parallel_studio_xe_2016.2.062 on Linux Mint 18.0 (based upon Ubuntu, kernel is 3.16.0-38-generic #52~14.04.1-Ubuntu SMP Fri May 8 09:43:57 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux)
The Intel C++ compiler runs fine but we had to change "Eclipse IDE for C++" to version "Kepler".
We tried to install / update the Error parser (had been working in Linux Mint 17.2 or 17.1) but to no avail.
Adding the source folder in Eclipse again did not help - everything looks like if the Eclipse package for Intel is installed, but still the Error parser does not work.
Which is the systematic way to check / install this?
Many thanks -
Andreas
Hi - who could I turn to to get an answer please?
Andreas
