Intel® C++ Compiler
7877 Discussions
Intel 64 mode: __STDC_DEC_FP__ defined, but _Decimal32 not known
tydeman
Hardware: Centrino 2 vPro (Core2Duo) in 64-bit mode
O.S.: Linux Fedora Core 10 in 64-bit mode
Compiler: Intel icc 11.1, 072 in Intel64 mode
Command line options: "-std=c99 -msse3 -O0 -fmath-errno -fp-model strict -fp-speculation=strict -H ${INCS}"
The Intel compiler icc 11.1 (in C99 mode) defines __STDC_DEC_FP__,
telling the user that decimal floating-point (DFP) is supported. Yet,
if you try to use DFP, the compiler complains about unknown types.
Program:
#define __STDC_WANT_DEC_FP__ 1 /* Tell compiler we want DFP */
#ifdef __STDC_DEC_FP__ /* Does compiler support DFP? */
_Decimal32 x;
#else
#error No support for DFP
#endif
Milind_Kulkarni__Int
New Contributor II
I think this issue was already raised by you in June month. The threadid in the forum is:-- 75585, and it looks same . Could you verify so that we do not duplicate the bug in the record. It also has to do with -std=c99 disabling the use of _Decimal FP types. Well, it works without the c99 option, but should work with that too, being a part of ISO C standard.
That issue is already escalated to developer team by the engineer. Please let me know.
tydeman
75585 has to do with IA-32 mode. This is with Intel 64 mode.
75585 has to do with not working after the user did
This has to do with __STDC_DEC_FP__ being defined by the
compiler, yet _Decimal32 not being usable.
New Contributor II
I have escalated it as a bug (here c99 corrupts Decimal FP usage).
I will keep you updated on the progress..
Judith_W_Intel
A macro doesn't turn on a feature, it indicates whether or not the feature is available on a particular platform. It should be used to check availability, not set it.
tydeman
The compiler is defining __STDC_DEC_FP__
My program is testing that symbol.
So, I do not understand your comment.
Judith_W_Intel
I'm sorry, I misread the first line of your program:
I thought this said __STDC_DEC_FP not __STDC_WANT_DEC_FP__.
Anyway, I understand your point now that if the compiler's not going to accept the DFPkeywords
it shouldn't define the macro. I agree.
This is entered as cq # DPD200159716.
Sorry for the confusion.
Judy
New Contributor II
This issue is fixed in latest compiler of 12.0.
For compatibility with GNU, we do not, and will not, recognize DFP types when -std=c99 is used.
Now, the __STDC_DEC_FP does not get defined, and the appropriate assertion comes.
tydeman
Since Decimal Floating-Point (DFP) is an extension built on top of C99, how do I get both C99 and DFP?
