I do some experiment with constexpr, I saw some error:
Minimal code, for reproduction:
#include <iostream>
template < typename Type >
struct A
static constexpr Type Func0() { return static_cast< Type >( 0.f ); }
static constexpr Type Func1() { return static_cast< Type >( 1.f ); }
struct Object
constexpr Object( Type const _a, Type const _b ) :
a( _a ),
b( _b )
private:
Type a;
Type b;
struct Const
static constexpr Type Func0Value = A< Type >::Func0();
static constexpr Type Func1Value = A< Type >::Func1();
static constexpr Object< Type > myObject( A< Type >::Func0(), A< Type >::Func1() );
int main()
std::cout << Const< int >::Func0Value << std::endl;
std::cout << Const< int >::Func1Value << std::endl;
std::cout << Const< float >::Func1Value << std::endl;
return 0;
Error:
1>main.cpp(28): error : function "A<Type>::Func0 [with Type=int]" is not a type name
1> static constexpr Object< Type > myObject( A< Type >::Func0(), A< Type >::Func1() );
1> ^
1> detected during instantiation of class "Const<Type> [with Type=int]" at line 33
1>
1>main.cpp(28): error : function "A<Type>::Func1 [with Type=int]" is not a type name
1> ^
1>
1>main.cpp(28): error : function "A<Type>::Func0 [with Type=float]" is not a type name
1> ^
1> detected during instantiation of class "Const<Type> [with Type=float]" at line 35
1>
1>main.cpp(28): error : function "A<Type>::Func1 [with Type=float]" is not a type name
1> ^
1>
1> compilation aborted for main.cpp (code 2)
Version of compiler:
Intel® C++ Composer XE 2013 SP1 Update 1 Integration for Microsoft* Visual Studio* 2012, Version 14.0.1278.11
I know en C++03 is not possible to instanciate non-integral object like that. But I would like to know if it is possible with C++11. For me everything is "parsable" at the compilation time.
The question: It is a C++11 limitation OR Compiler issue?
You are not using correct syntax for initializing a static data member.
The GNU compiler gives similar errors, i.e.:
sptxl8-72> g++48 -std=c++11 -c ex2.cpp
ex2.cpp:28:61: error: A<Type>::Func0 is not a type
ex2.cpp:28:81: error: A<Type>::Func1 is not a type
The initialization needs to be done with this syntax:
#ifdef OK // valid
static constexpr Object< Type > myObject = Object<Type>( A< Type
#else // not valid
>::Func1() );
#endif
Unfortunately the above does not work with our 14.0 compiler (an error
message about "expression must have a constant value" will occur).
But it will compile with GNU and it works with our development compiler
which will become our next compiler release.
Judy
