Hi
I'm getting a compile error using intel C++ 15.04 and 16.0 on linux 64. Note I do not get the same errors building on a windows platform:
/.../distro/boost_1_59_0/boost/thread/detail/nullary_function.hpp(184): error: more than one instance of constructor "boost::detail::nullary_function<R ()>::impl_type<F>::impl_type [with R=size_t={unsigned long}, F=boost::thread_detail::default_barrier_reseter]" matches the argument list: function "boost::detail::nullary_function<R ()>::impl_type<F>::impl_type(boost::detail::thread_move_t<F>) [with R=size_t={unsigned long}, F=boost::thread_detail::default_barrier_reseter]" function "boost::detail::nullary_function<R ()>::impl_type<F>::impl_type(const boost::detail::nullary_function<size_t={unsigned long} ()>::impl_type<boost::thread_detail::default_barrier_reseter> &) [with R=size_t={unsigned long}, F=boost::thread_detail::default_barrier_reseter]" argument types are: (boost::thread_detail::default_barrier_reseter) impl(new impl_type<typename decay<F>::type>(thread_detail::decay_copy(boost::forward<F>(f)))) ^ detected during instantiation of "boost::detail::nullary_function<R ()>::nullary_function(boost::detail::thread_move_t<F>) [with R=size_t={unsigned long}, F=boost::thread_detail::default_barrier_reseter]" at line 139 of "/opt/app/caf/builds/smitaau/lib//distro/boost_1_59_0/boost/thread/barrier.hpp" /.../boost_1_59_0/boost/thread/detail/nullary_function.hpp(184): error: more than one instance of constructor "boost::detail::nullary_function<R ()>::impl_type<F>::impl_type [with R=size_t={unsigned long}, F=boost::thread_detail::void_fct_ptr_barrier_reseter]" matches the argument list: function "boost::detail::nullary_function<R ()>::impl_type<F>::impl_type(boost::detail::thread_move_t<F>) [with R=size_t={unsigned long}, F=boost::thread_detail::void_fct_ptr_barrier_reseter]" function "boost::detail::nullary_function<R ()>::impl_type<F>::impl_type(const boost::detail::nullary_function<size_t={unsigned long} ()>::impl_type<boost::thread_detail::void_fct_ptr_barrier_reseter> &) [with R=size_t={unsigned long}, F=boost::thread_detail::void_fct_ptr_barrier_reseter]" argument types are: (boost::thread_detail::void_fct_ptr_barrier_reseter) impl(new impl_type<typename decay<F>::type>(thread_detail::decay_copy(boost::forward<F>(f)))) ^ detected during instantiation of "boost::detail::nullary_function<R ()>::nullary_function(boost::detail::thread_move_t<F>) [with R=size_t={unsigned long}, F=boost::thread_detail::void_fct_ptr_barrier_reseter]" at line 204 of "/opt/app/caf/builds/smitaau/lib//distro/boost_1_59_0/boost/thread/barrier.hpp"
Here's a small standalone example that replicates the issue:
#include <boost/thread.hpp> #include <tr1/memory> template <typename T> class ThreadLocalData { private: /// all local storage for this type static boost::thread_specific_ptr<T> &instance() { static boost::thread_specific_ptr<T> sTLS; return sTLS; } public: /// get an instance of thread local storage static T& getThreadLocalInstance() { T* pT = instance().get(); if (!pT) { pT = new T; instance().reset(pT); } return *pT; } /// Destroy the current instance of threadlocal data by resetting it. static void destroy() { instance().reset(); } }; namespace { class ThreadData { public: ThreadData() : myValue() { myValue.reset(new int(1)); } std::tr1::shared_ptr<int> getValue() const { return myValue; } ~ThreadData() { } private: std::tr1::shared_ptr<int> myValue; }; } int& get() { return *ThreadLocalData<ThreadData>::getThreadLocalInstance().getValue(); } int main() { return get(); }
Compile this with
$ icpc -I <path_to_boost_1_59> -fpermissive test.cpp
and you should see the error. But is you remove the -fpermissive arg then the error goes away. This is strange, since I would expect this flag actually make the compiler more forgiving rather than less forgiving,
Any ideas?
I can see this also. I opened DPD200376337 to track the problem. Thank you for reporting it.
--Melanie
Melanie, I've added the defect number to this issue so I can let Scott know on this thread when the release with a fix is out, thanks.
_Kittur
Hi Scott,
Just letting you know that this issue is fixed in the latest 16.0 update 2 release which you can download and test it out. Thanks for bringing this issue to our attention and patience through this issue as well.
Kittur
