Intel® C++ Compiler
7833 Discussions
Intel C++ 16 and boost 1.59 compilation error
Scott_S-S_
Hi
I'm getting a compile error using intel C++ 15.04 and 16.0 on linux 64. Note I do not get the same errors building on a windows platform:
/.../distro/boost_1_59_0/boost/thread/detail/nullary_function.hpp(184): error: more than one instance of constructor "boost::detail::nullary_function<R ()>::impl_type<F>::impl_type [with R=size_t={unsigned long}, F=boost::thread_detail::default_barrier_reseter]" matches the argument list:
            function "boost::detail::nullary_function<R ()>::impl_type<F>::impl_type(boost::detail::thread_move_t<F>) [with R=size_t={unsigned long}, F=boost::thread_detail::default_barrier_reseter]"
            function "boost::detail::nullary_function<R ()>::impl_type<F>::impl_type(const boost::detail::nullary_function<size_t={unsigned long} ()>::impl_type<boost::thread_detail::default_barrier_reseter> &) [with R=size_t={unsigned long}, F=boost::thread_detail::default_barrier_reseter]"
            argument types are: (boost::thread_detail::default_barrier_reseter)
        impl(new impl_type<typename decay<F>::type>(thread_detail::decay_copy(boost::forward<F>(f))))
          detected during instantiation of "boost::detail::nullary_function<R ()>::nullary_function(boost::detail::thread_move_t<F>) [with R=size_t={unsigned long}, F=boost::thread_detail::default_barrier_reseter]" at line 139 of "/opt/app/caf/builds/smitaau/lib//distro/boost_1_59_0/boost/thread/barrier.hpp"
/.../boost_1_59_0/boost/thread/detail/nullary_function.hpp(184): error: more than one instance of constructor "boost::detail::nullary_function<R ()>::impl_type<F>::impl_type [with R=size_t={unsigned long}, F=boost::thread_detail::void_fct_ptr_barrier_reseter]" matches the argument list:
            function "boost::detail::nullary_function<R ()>::impl_type<F>::impl_type(boost::detail::thread_move_t<F>) [with R=size_t={unsigned long}, F=boost::thread_detail::void_fct_ptr_barrier_reseter]"
            function "boost::detail::nullary_function<R ()>::impl_type<F>::impl_type(const boost::detail::nullary_function<size_t={unsigned long} ()>::impl_type<boost::thread_detail::void_fct_ptr_barrier_reseter> &) [with R=size_t={unsigned long}, F=boost::thread_detail::void_fct_ptr_barrier_reseter]"
            argument types are: (boost::thread_detail::void_fct_ptr_barrier_reseter)
          detected during instantiation of "boost::detail::nullary_function<R ()>::nullary_function(boost::detail::thread_move_t<F>) [with R=size_t={unsigned long}, F=boost::thread_detail::void_fct_ptr_barrier_reseter]" at line 204 of "/opt/app/caf/builds/smitaau/lib//distro/boost_1_59_0/boost/thread/barrier.hpp"
Here's a small standalone example that replicates the issue:
#include <boost/thread.hpp>
#include <tr1/memory>
template <typename T>
class ThreadLocalData
private:
  /// all local storage for this type
  static boost::thread_specific_ptr<T> &instance() {
    static boost::thread_specific_ptr<T> sTLS;
    return sTLS;
public:
  /// get an instance of thread local storage
  static T& getThreadLocalInstance()
    T* pT = instance().get();
    if (!pT)
      pT = new T;
      instance().reset(pT);
    return *pT;
  /// Destroy the current instance of threadlocal data by resetting it.
  static void destroy()
    instance().reset();
namespace {
class ThreadData
public:
  ThreadData() : myValue()
    myValue.reset(new int(1));
  std::tr1::shared_ptr<int> getValue() const { return myValue; }
  ~ThreadData() { }
private:
  std::tr1::shared_ptr<int> myValue;
int& get()
  return *ThreadLocalData<ThreadData>::getThreadLocalInstance().getValue();
int main()
  return get();
Compile this with
$ icpc -I <path_to_boost_1_59> -fpermissive test.cpp
and you should see the error. But is you remove the -fpermissive arg then the error goes away. This is strange, since I would expect this flag actually make the compiler more forgiving rather than less forgiving,
Any ideas?
Melanie_B_Intel
I can see this also. I opened DPD200376337 to track the problem. Thank you for reporting it.
--Melanie
Kittur_G_Intel
Melanie, I've added the defect number to this issue so I can let Scott know on this thread when the release with a fix is out, thanks.
_Kittur
Kittur_G_Intel
Hi Scott,
Just letting you know that this issue is fixed in the latest 16.0 update 2 release which you can download and test it out. Thanks for bringing this issue to our attention and patience through this issue as well.
Kittur
