After upgrading the Intel C++ Compiler from 14.0 to 17.0 in Linux, some parts of our code started to generate the following compiler crash when compiling the optimized (-02) build:
* Segmentation violation signal raised. *
Access violation or stack overflow. Please contact Intel Support for assistance.
- Environment: RHEL6, devtoolset-2 (which uses gcc 4.8.2)
- The crash only happens in (-02), not in (-01) nor in debug.
- Some crashes have been narrowed down to cilk_for-loop and go away when using regular for-loop.
Are there known issues with gcc 4.8.2? With cilk? Is that too old? Crashes also seem to go away when using newer gcc-version, but ideally we would not change due to all third party library dependencies.
Thanks!
Jussi Lehto
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Hi Jussi,
Can you identify a source file which failed to compile, then generate a pre-processed file for us to investigate?
Viet Hoang
