Background: I am compiling "lubridate" package for R using Intel compiler on a shared HPC cluster, and I am facing an issue at the linking stage of the library.
Lubridate package: https://cran.r-project.org/web/packages/lubridate/index.html
Here is the icpc invocation at the linking stage, and the error message:
icpc -std=gnu++11 -shared -L/cm/shared/applications/R/3.4.3/lib64/R/lib -Wl,-z,relro,-z,now -qopenmp -L/cm/shared/applications/zlib/1.2.8/lib -L/cm/shared/applications/bzip2/1.0.6/lib -L/cm/shared/applications/xz/5.2.3/lib -L/cm/shared/applications/build_essential/1.0/lib -o lubridate.so RcppExports.o datetime.o period.o tparse.o update.o utils.o -L. -lcctz -L/cm/shared/applications/R/3.4.3/lib64/R/lib -lR ipo: warning #11012: unable to find -lgcc ipo: warning #11012: unable to find -lgcc ld: error: cannot find -lgcc ld: error: cannot find -lgcc ld: error: cannot find -lgcc ld: error: cannot find -lgcc make: *** [lubridate.so] Error 1 ERROR: compilation failed for package ‘lubridate’
Software versions: Intel compiler suite version 18.0.3, g++ version 6.4.0. Note that the g++ located in a non-default location because we have multiple GCC versions on the system. FWIW, the g++ path is: /cm/shared/applications/gcc/6.4.0/bin/g++ .
After some digging (with "icpc -v", and experimenting on that computer), I found that there is one "-L" path missing. On my site, the missing path was:
/cm/shared/applications/gcc/6.4.0/lib/gcc/x86_64-redhat-linux/6.4.0/
which was not included in g++ search path (as evidenced when I invoked `g++ -print-search-dirs`). I could do ad-hoc solution by adding the directory above to LIBRARY_PATH environment variable. But I wonder if there is a better solution. (What was started as a Intel C++ problem seem to end up being a GCC problem, but I want to post this anyway because somebody else may have run into the same issue. I could not find any discussion on this on the internet.)
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Would it help if you compile with -gxx-name=/cm/shared/applications/gcc/6.4.0/bin/g++ ?
Viet
