the following C++ program does not compile on Intel Parallel Composer XE 2013 integrated in Visual Studio 2012 (tried on two different machines with newly setup windows 7 SP1):
#include <atomic>
#include <vector>
int main(int, char* [])
std::atomic_uint ax;
return 0;
the compiler generates the following error messages:
Error 1 error : invalid redeclaration of type name "std::memory_order" (declared at line 89 of "C:\Program Files (x86)\Intel\Composer XE 2013\compiler\include\stdatomic.h") C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\include\xatomic0.h 18
Error 2 error : "memory_order_relaxed" has already been declared in the current scope C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\include\xatomic0.h 19
Error 3 error : "memory_order_consume" has already been declared in the current scope C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\include\xatomic0.h 20
Error 4 error : "memory_order_acquire" has already been declared in the current scope C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\include\xatomic0.h 21
Error 5 error : "memory_order_release" has already been declared in the current scope C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\include\xatomic0.h 22
Error 6 error : "memory_order_acq_rel" has already been declared in the current scope C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\include\xatomic0.h 23
Error 7 error : "memory_order_seq_cst" has already been declared in the current scope C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\include\xatomic0.h 24
the issue seems to come from double definition of the memory_order enum located in an internal header <xatomic0.h> that is included by <vector> header that comes with visual C++ 11
the second definition is located in <stdatomic.h> that is previously included by <atomic> header required by intel C++ 2013 compiler (the actual header that defines this enum is <stdatomic.h> on intel C++ 2013)
to work around this problem I need to add the following preprocessor definition guard that excludes the problematic header <xatomic0.h> prior to any inclusion:
#ifdef __INTEL_COMPILER
#define _XATOMIC0_H // include guard used in <xatomic0.h>
#endif // __INTEL_COMPILER
#include <atomic>
#include <vector>
return 0;
I could not find any topic regarding this issue on intel forums - so I decided to create a new topic to show this issue.
my guess is that the proper fix would require to change some internal header included by <atomic> that come with intel c++ 2013 compiler.
I hope this will be fxed as soon as possible.
I forgot to mention the compilation options - because for this issue these are not relevant: default option with debug / release Win32 / x64 - all reproduce this problem.
