Hi
OS : Windows 10, X64
Intel C++ 2021.1.3 Classic
Target : X86
I discovered that _InterlockedCompareExchangePointer is unresolved external in target X86 (but works fine in X64), Here is how to reproduce (silly example) in target x32
#include <iostream>
#include <intrin.h>
int main()
void* a1, * a2= nullptr, * a3 = nullptr;
_InterlockedCompareExchangePointer(&a1, a2, a3);
Is intrinsic in x32 broken?
Our Developer decided not to fix this issue. Please use icx instead.
We are going to close this thread as wont fix.
Hi Peter,
We tried the code snippet at our end using Intel oneAPI 2021.2 and 2021.3. We found it runs fine for both x86 and x64 on Windows 10 using the C++ compiler.
Can you please consider working on latest version of Intel oneAPI i.e. 2021.3? Let us know if issue persists.
Thanks!
Thank you for your reply
I regretfully didn't clarify compiler version, but it was the latest, 2021.3
I am still getting unresolved external on this intrinsic
I attach a command line compile of this small example. All version information is also shown
Using same example using X64 target does not produce this error, as I show in attachment
Would you please have a look at it again?
Hi Peter,
We were able to reproduce the same issue with the icl compiler.
We are working on your issue internally. We will get back to you soon.
Meanwhile could you please try compiling your code with icx compiler instead of icl.
Thanks!
Thank for reporting this issue. I've filed this bug to our Developer.
