Intel® C++ Compiler
Intel C++ Compiler 17.0 Update 5 + VS2017 5.7.1 = Access Violation
jase439
This code snippet:
#include <exception>
#include <iostream>
int main()
   try
      throw std::runtime_error("Hello World!");
   catch (const std::exception &e)
      std::cout << e.what() << std::endl;
   return 0;
Produces the following output:
1>------ Rebuild All started: Project: HelloWorld, Configuration: Debug Win32 ------
1>stdafx.cpp
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\include\xmemory0(189): error : identifier "__STDCPP_DEFAULT_NEW_ALIGNMENT__" is undefined
1>      enable_if_t<(!_HAS_ALIGNED_NEW || _Align <= __STDCPP_DEFAULT_NEW_ALIGNMENT__), int> = 0> inline
1>                                                  ^
1>
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\include\xtr1common(59): error : class "std::enable_if<<error-constant>, int>" has no member "type"
1>      using enable_if_t = typename enable_if<_Test, _Ty>::type;
1>                                                          ^
1>          detected during instantiation of type "std::enable_if_t<<error-constant>, int>" at line 189 of "C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\include\xmemory0"
1>
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\include\xmemory0(208): error : identifier "__STDCPP_DEFAULT_NEW_ALIGNMENT__" is undefined
1>                                                  ^
1>
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\include\memory(2514): error : access violation
1>      enable_if_t<is_array_v<_Ty> && extent_v<_Ty> == 0, int> = 0>
1>                                                 ^
1>
1>compilation aborted for stdafx.cpp (code 4)
1>Done building project "HelloWorld.vcxproj" -- FAILED.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
shan__yingchun
Hi~this problem can be solved by reinstalling Parallel Studio XE 2018 Update2 instead of Parallel Studio XE 2017 Update*.
Viet_H_Intel
Did you mean VS2017 15.7.1? If so, you hit this issue because Intel compiler (version 17.0) doesn't support VS2017 15.7.1. It only supports up to VS2017 15.3.*.
Viet
jase439
Thanks. I will test 2018 (update 2) with 15.7.1. Do you know if ICC 17 will be updated to support > VS2017 15.3.* or has that version of ICC gone EOL?
jase439
Good results with 15.7.x and ICC 18 Update 2. I would still be interested to know if ICC 17 will see another update or if 15.3.x is the terminal stop for that product.
jase439
Can anyone from Intel comment as to whether or not support for VS 15.7.x is on the update roadmap for ICC 17?
