I compile project in Visual Studio 2015 with Intel C++ Compiler 17 without any error. Modify some codes and compile again without any errors again.
But when I shutdown the computer and turn on again, compiler fails and throws this into output screen:
1>": : error : ** The compiler has encountered an unexpected problem.
1> ** Segmentation violation signal raised. **
1> Access violation or stack overflow. Please contact Intel Support for assistance.
1>
1> compilation aborted for ..\..\Sources\Shared\UnitTypes.cpp (code 4)
Last line can be anything. It isn't because of UnitTypes.cpp. It can be any class file in later errors. And in error list:
After that I have to build and compile the whole solution and it takes too much time. Everytime when I shutdown computer and open again, I have to do that.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
We have not seen this before and need to have a way to reproduce it to understand what might have happened.
Can you try it on another system to see if the error still occurs?
Viet Hoang
I just found the same problem.
Intel Compiler 2017, C99 project.
Compiler options:
/GS- /TC /Qopenmp /Qcheck-pointers:rw /GA /Qrestrict /Qftz /W4 /QxSSE3 /Zc:wchar_t /Zi /O3 /Ob2 /Fd"x64\Release\vc140.pdb" /fp:fast=2 /Quse-intel-optimized-headers /Qcheck-pointers-dangling:all /D "WIN32" /D "NDEBUG" /D "_WINDOWS" /D "MYSDL_MEVIS" /D "_MBCS" /Qipo /Zc:forScope /GR- /Qopt-matmul /Oi /MT /QaxCORE-AVX2 /Fa"x64\Release\" /nologo /Fo"x64\Release\" /Qprof-dir "x64\Release\" /Qstd=c99 /Ot /Fp"x64\Release\CAT3D.pch"
Plus additional options:
/Qdiag-disable:1786,2557,3280,344,1879 /Qprec-div- /Qlong-double
