Hello Forum member,
I want to know detailed ARM architecture and GNU C++ Compiler supports about Intel C++ Compiler for Android.
1.Exact product name and version of ARM & GNU C++ Compiler which are supported in Intel C++ Compiler for Android.
(Does This compiler cover what kind of system?)
2.Is there the support when I can't understand setting and operation method of ARM & GNU C++ Compiler?
3.What is the merit of including ARM & GNU C++ Compiler in Intel C++ Compiler for Android?
Thank you for your help.
Hide10
The posted descriptions seem clear that the intel compiler doesn't affect the arm support in the android sdk. I thought it was based on llvm (note the availability of a MacOS host). The point is to support intel cpus.
Hello Tim,
Thank you for your reply.
I was understanding mistaken about this problem.
I could have correct understandings.
Thank you!
Hideto
The Intel C++ Compiler for Android contains only the Intel C++ compiler for Intel x86 architecture. It does not contain other compilers.
See the "Getting Started Guide" under the "Documentation" on how to use Intel C++ Compiler from a command window or Eclipse.
Jennifer
Hello Jennifer,
Thank you for your comment.
I didn't know how to investigate the Intel products.
I read the Getting Started Guide.
Thank you.
Hideto
