Hi All.
I am using ICC -v11.0, would like to understand ELF(Executable Link Format) on Linux.
Query -
(a) Is there any way to detect and examine ELF type and it's header using ICC?
(b) Any way using ICC v11.0 where I can get information of Process map?
(c) Any documents or links from Intel which discusses all informations of ELF header, it's sections & Process Map in detail?
(d) Also, can I have Intel Binutils references or it's links for understanding?
I checked "/apps/intel/cce/11.0.74/bin/intel64" to find out the Compiler/Binutils driver which can help me with all above, but not able to identify.
~BR
Query -
~BR
icc doesn't alter the binutils you have installed; you have exactly the same binutils functionality regardless of whether you compile with gcc or icc, or a combination. The current html doc is at http://sourceware.org/binutils/docs/
Quoting - tim18
I am not sure how ICC v11.0 was installed as simply I am a user of it.
AFAIK, Binutils would be a part of ICC Toolchain.
In GCC, if I am not wrong, readelf helps in knowing the ELF section of it's header, similary ICC might have something to understand the ELF generated using ICC.
I would need support for above queries from Intel community as asked - (a), (b), (c) & (d) for having proper ICC Toolchain utility insights for my work.
~BR
Quoting - srimks
Quoting - srimks
Hi All.
Query -
~BR
Query -
~BR
Hi All.
I got the answers as I tried experimenting myself for all above as -
(a) One can use "readelf", but this "readelf" would be "/usr/bin/readelf".
(b) One can refer all sections (data, bss, rodata,text, etc.)information using "readelf".
(c) Refer http://www.sco.com/developers/gabi
http://www.sco.com/developers/devspecs
(d) There is no Intel created Binutils. Intel uses GNU Binutils.
Refer http://sources.redhat.com/binutils
Please correct and do add some more info. if needed to all above.
~BR
