i use
icl /MD test.cpp tbb.lib command but always get catastrofic errors.
could be the env not seting up right. Because I tried the icl 10.1.020 and TBB 2.0.017, it works fine for me with VS2005.
Here is what you should do:
. open abuild env from Intel C++ Compiler menu : start -> all programs -> Intel software tools->Intel C++ Compiler->Build env for IA32.....
. from the cmd window, call "C:Program FilesIntelTBB2.0ia32vc8in bbvars.bat"
. compile your test again.
did what you mentioned but now i get an error: "MSVCP80.dll" is missing...madjljiang:could be the env not seting up right. Because I tried the icl 10.1.020 and TBB 2.0.017, it works fine for me with VS2005.
Add "C:Program FilesMicrosoft Visual Studio 8VC edistx86Microsoft.VC80.CRT" to your path like:
>> set path=C:Program FilesMicrosoft Visual Studio 8VC edistx86Microsoft.VC80.CRT;%path%
Then run the program again.
