Hi all,
I'm using Intel C++ Compiler 14.0.3 and libc++ on Mac OS X 10.9.3. The following code compiles cleanly in clang and gcc but not on icpc. Maybe a compiler bug?
Many thanks,
-mc.
#include <tuple> #include <algorithm> #include <vector> typedef std::tuple<double, double, double> DataTuple; int main(void) { struct comparator { bool operator() (const DataTuple& a, const DataTuple& b) { return (std::get<0>(a) < std::get<0>(b)); } } mycomp; std::vector<DataTuple> vec; std::sort(vec.begin(), vec.end(), mycomp); return 0; }
Error message:
/mylibcxx/include/tuple(174): error: identifier "_Hp" is undefined
_NOEXCEPT_(__is_nothrow_swappable<_Hp>::value)
detected during:
instantiation of "void std::__1::swap(std::__1::__tuple_leaf<_Ip, _Hp, _Ep> &, std::__1::__tuple_leaf<_Ip, _Hp, _Ep> &) [with _Ip=0UL, _Hp=double, _Ep=false]" at line 3340 of "/mylibcxx/include/type_traits"
instantiation of class "std::__1::__is_nothrow_swappable_imp<<unnamed>, _Tp> [with <unnamed>=true, _Tp=std::__1::__tuple_leaf<0UL, double, false>]" at line 3352 of "/mylibcxx/include/type_traits"
instantiation of class "std::__1::__is_nothrow_swappable<_Tp> [with _Tp=std::__1::__tuple_leaf<0UL, double, false>]" at line 284
instantiation of "int std::__1::__tuple_leaf<_Ip, _Hp, <unnamed>>::swap(std::__1::__tuple_leaf<_Ip, _Hp, <unnamed>> &) [with _Ip=0UL, _Hp=double, <unnamed>=false]" at line 285
instantiation of "int std::__1::__tuple_leaf<_Ip, _Hp, <unnamed>>::swap(std::__1::__tuple_leaf<_Ip, _Hp, <unnamed>> &) [with _Ip=0UL, _Hp=double, <unnamed>=false]" at line 481
instantiation of "void std::__1::__tuple_impl<std::__1::__tuple_indices<_Indx...>, _Tp...>::swap(std::__1::__tuple_impl<std::__1::__tuple_indices<_Indx...>, _Tp...> &) [with _Indx=<0UL, 1UL, 2UL>, _Tp=<double, double, double>]" at line 670
instantiation of "void std::__1::tuple<_Tp...>::swap(std::__1::tuple<_Tp...> &) [with _Tp=<double, double, double>]" at line 704
instantiation of "std::__1::enable_if<std::__1::__all<std::__1::__is_swappable<_Tp>::value...>::value, void>::type std::__1::swap(std::__1::tuple<_Tp...> &, std::__1::tuple<_Tp...> &) [with _Tp=<double, double, double>]" at line 3840 of "/mylibcxx/include/algorithm"
instantiation of "void std::__1::__sort(_RandomAccessIterator, _RandomAccessIterator, _Compare) [with _Compare=comparator &, _RandomAccessIterator=DataTuple *]" at line 4025 of "/mylibcxx/include/algorithm"
instantiation of "void std::__1::sort(_RandomAccessIterator, _RandomAccessIterator, _Compare) [with _RandomAccessIterator=DataTuple *, _Compare=comparator &]" at line 4059 of "/mylibcxx/include/algorithm"
instantiation of "void std::__1::sort(std::__1::__wrap_iter<_Tp *>, std::__1::__wrap_iter<_Tp *>, _Compare) [with _Tp=DataTuple, _Compare=comparator]" at line 19 of "icpc_bug.cpp"
Hi Matteo,
I've got a problem report on this issue into our front-end team. I'll keep you posted on their status. Unfortunately, I don't know of a workaround at this point.
Looks like an error during header file parsing phase.
Yes, it is obvious that the error happens when the header file is processed :) But I suspect that icpc has some template-related stuff broken, since the same code has no problems when compiled with clang or gcc.
It looks like known issue. Internal tracker #254500.
I'll post a status changes here.
--Sergey
