Is Intel C++ supported on Windows 7(beta) ??
Quoting - pramodblackbird
As tim18 said it should work.
Regardless of that, Professional and higher versions of Windows 7 will have Windows XP SP3 compatible mode (realized through Virtual PC) where any Windows XP compatible application should work just like it did in Windows XP. This thing called XPM will be available for download as an optional component and XP SP3 license will be included with Windows 7 purchase.
I hope that Intel now understands why all notebooks need virtualization enabled.
I tried the Parallel Studio on Windows 7 PC version, did not see any issue but did encounter a bug related to mt.exe. See following link for more info:
http://www.wintellect.com/CS/blogs/jrobbins/archive/2009/01/24/the-case-of-the-corrupt-pe-binaries.aspx .
Jennifer
Jennifer
I should note that we do not officially support any beta OS. It's not fully tested yet. The beta OS will be changing till RTM. So it does not make sense to run full testing or make changes in our product.
But I didn't see any issue so far except the mt.exe issue above.
Jennifer
Jennifer
