int i = 0;
switch ( i )
case 0:
// some code
i = 1;
break; // if optimization is disabled everything works as supposed, but if intel optimization is enabled this "break" doesn't exist and execution goes into case 1 body
case 1:
// some code
break;
I used Parallel Studio XE2013 an XE2016 update 3. Exact code is:
enum POLYSTATE
START,
TOP,
BOTTOM
} state = START;
for (; i < pRgnData->rdh.nCount; ++i)
switch (state)
case START:
pRastrTool->NewLine();
if (!pRastrTool->AddDscrSeg(pRect.top, pRect.left, pRect.right))
bErr = true;
yPrev = pRect.top;
iStart = i;
state = TOP;
} break;
case TOP:
if (yPrev == pRect.top)
bErr = true;
yPrev = pRect.top;
else
i = iStart;
if (!pRastrTool->AddDscrSeg(pRect.bottom, pRect.left, pRect.right))
bErr = true;
yPrev = pRect.bottom;
state = BOTTOM;
} break;
case BOTTOM:
if (yPrev == pRect.bottom)
bErr = true;
else
iStart = i;
else
pRastrTool->Split();
bErr = true;
yPrev = pRect.top;
state = TOP;
} break;
When any kind of optimization is enabled I can clearly see that "break" is ignored and execution flows into next case body. I had to add extra variable to avoid the issue.
Strange. I couldn't reproduce the fall-through with either ICC, gcc, clang.
I simplified the code to :
#include <iostream> int main() { enum POLYSTATE { START, TOP, BOTTOM } state = START; for (int i = 0; i < 10; ++i) { switch (state) { case START: { state = TOP; std::cout << "start" << std::endl; } break; case TOP: { state = BOTTOM; std::cout << "top" << std::endl; } break; case BOTTOM: { state = TOP; std::cout << "bottom" << std::endl; } break; } } }
I would recommend taking a look at the generated code.
By the way, does it work as expected with other compilers?
It works as expected with visual studio compiler as well with the intel compiler with optimizations disabled. When intel optimization enabled the execution fails.
Checked with Clang 3.7. Works fine as well. It strongly seems the bug is intel C++ specific.
