Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
Intel CodeCov on VxWorks target
Eric_M_
I am trying to perform code coverage on a subset of code that is using VxWorks as an O.S. When I compile everything with the intel compiler using the -prof-gen:srcpos flag it seems to generate the correct static profile instrumentation. However, when I run the executable, there are undefined symbols. At first, it symbols was specific to the libipgo.a library, but after I included that library, it gave me another undefined symbol error saying "__exit" was not defined. Are there any ideas on how to get rid of this error? Any help would be appreciated.
Viet_H_Intel
Hi Eric,
Did your code run successfully when compile without -prof-gen:srcpos?
Do you know who called __exit?
Viet Hoang
