But I have these errors:
/usr/include/c++/4.3.4/type_traits(82): error: expected a ">"
struct is_rvalue_reference<_Tp&&>
/usr/include/c++/4.3.4/type_traits(106): error: expected a ">"
struct remove_reference<_Tp&&>
/usr/include/c++/4.3.4/type_traits(136): catastrophic error: rvalue references not yet implemented
{ typedef _Tp&& type; };
compilation aborted
Why compiler uses the headers with rvalue references?
How to avoid these errors?
Thanks!
Looks like there is some reference in what you're compiling to the C++0x rvalue feature. This is supported in the Intel Compiler but you'll have to use the option: -std=c++0x when you compile to enable the C++0x feature. Let me know if that resolves your issue?
-regards,
Kittur
-regards,
KIttur
Thanks for the input. You can try the following:
Try adding -U__GXX_EXPERIMENTAL_CXX0X__
This works with 11.1 and gcc 4.4 (and failed without...)
Let me know if that helps. Of course, in the next release of icc for Linux, rvalue is supported so this should not be an issue.
_Cheers,
Kittur
I have allready use Intel Compiler 11.1.073 on Ubuntu 10.4 without problem
I think just at the shell (bash) execute before to compile
export LANG=C;
(UTF8 translate problem ">")
What do you mean sayingUTF8 translate problem ">"(just for my interest)
your message error given (expected a '>')/usr/include/c /4.3.4/type_traits(82): error: expected a '>'
I think without other flag added probably ,it could work also with
LANG=C;export LANG;
Encoding as personal is really complex problem ,
Single Situation example:
when you communicate (Cloud server)
engine database with backend C/C
Think that now you having also tactile screen that keyboard encoding can be changed dynamically by user.
also some characters are not converted by UTF8.
Using C (ascii) could be is better for working with only one unique reference.
if your programming must be working shared on the www.
regards
LANG=C;export LANG;
regards
Nice to know the flag U__GXX_EXPERIMENTAL_CXX0X__ worked fine in turning off rvalue header errors.
Hi Bustaf, since icc 11.1 doesn't support C++0x rvalue feature (is supported in next upcoming release. Of courseit's supportedalready in Parallel Composer 2011 for Windows* though) without the above flag it's not possible to turn off the errors. The LANG option of course is good to set the proper locale setting....
-regards,
Kittur
Thanks Bustaf. Yes I do understand it's important to set the LANG option (BTW, yes it's LANG+C is default for Ubuntu). I was only trying to mention that the switch I suggested is still the solution to turn off the rvalue reference header errors since it's not supported in 11.1 version, that's all. But, I do get your message on the importance of LANG setting, appreciate that.
-regards,
Kittur
-Cheers,
Kittur
I am trying to compile OpenFOAM CFD package in SUSE Enterprise HPC Cluster.
I was struggling with same errors but U__GXX_EXPERIMENTAL_CXX0X__ switch solve the problem. However, now new type of error is coming, it is related to the overload definitions in compiling. A snippet of same is pasted below:
SOURCE=LienCubicKE/LienCubicKE.C ; icpc -std=c++0x -Dlinux64 -DWM_DP -wd327,525,654,819,1125,1476,1505,1572 -DNoRepository -I/home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels -I/home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/transportModels -I/home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude -I/home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/meshTools/lnInclude -IlnInclude -I. -I/home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude -fPIC -U__GXX_EXPERIMENTAL_CXX0X__ -c $SOURCE -o Make/linux64IccDPOpt/LienCubicKE.o SOURCE=LienCubicKELowRe/LienCubicKELowRe.C ; icpc -std=c++0x -Dlinux64 -DWM_DP -wd327,525,654,819,1125,1476,1505,1572 -DNoRepository -I/home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels -I/home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/transportModels -I/home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude -I/home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/meshTools/lnInclude -IlnInclude -I. -I/home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude -fPIC -U__GXX_EXPERIMENTAL_CXX0X__ -c $SOURCE -o Make/linux64IccDPOpt/LienCubicKELowRe.o /home1/rsoni/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricSymmTensorField.C(56): error: more than one instance of overloaded function "Foam::dot" matches the argument list: function template "void Foam::dot(Foam::GeometricField<Foam::innerProduct<Type1, Type2>::type, PatchField, GeoMesh> &, const Foam::GeometricField<TypeR, PatchField, GeoMesh> &, const Foam::GeometricField<Type1, PatchField, GeoMesh> &)" function template "void Foam::dot(Foam::GeometricField<Foam::tensor, PatchField, GeoMesh> &, const Foam::GeometricField<Foam::symmTensor, PatchField, GeoMesh> &, const Foam::GeometricField<Foam::symmTensor, PatchField, GeoMesh> &)" argument types are: (Foam::GeometricField<Foam::tensor, Foam::fvPatchField, Foam::volMesh>, const Foam::GeometricField<Foam::symmTensor, Foam::fvPatchField, Foam::volMesh>, const Foam::GeometricField<Foam::symmTensor, Foam::fvPatchField, Foam::volMesh>) BINARY_OPERATOR(tensor, symmTensor, symmTensor, &, '&', dot) ^ detected during instantiation of "Foam::tmp<Foam::GeometricField<Foam::tensor, PatchField, GeoMesh>> Foam::operator&(const Foam::GeometricField<Foam::symmTensor, PatchField, GeoMesh> &, const Foam::GeometricField<Foam::symmTensor, PatchField, GeoMesh> &) [with PatchField=Foam::fvPatchField, GeoMesh=Foam::volMesh]" at line 59 of "realizableKE/realizableKE.C" compilation aborted for realizableKE/realizableKE.C (code 2) make: *** [Make/linux64IccDPOpt/realizableKE.o] Error 2
The file where I added the switch looks like below:
service0 rules/linux64Icc> cat c++ .SUFFIXES: .C .cxx .cc .cpp c++WARN = -wd327,525,654,819,1125,1476,1505,1572 CC = icpc -std=c++0x include $(RULES)/c++$(WM_COMPILE_OPTION) ptFLAGS = -DNoRepository c++FLAGS = $(GFLAGS) $(c++WARN) $(c++OPT) $(c++DBUG) $(ptFLAGS) $(LIB_HEADER_DIRS) -fPIC -U__GXX_EXPERIMENTAL_CXX0X__ Ctoo = $(WM_SCHEDULER) $(CC) $(c++FLAGS) -c $$SOURCE -o $@ cxxtoo = $(Ctoo) cctoo = $(Ctoo) cpptoo = $(Ctoo) LINK_LIBS = $(c++DBUG) -L$(IA64ROOT)/lib LINKLIBSO = $(CC) $(c++FLAGS) -shared -Xlinker --add-needed -Xlinker --no-as-needed LINKEXE = $(CC) $(c++FLAGS) -Xlinker --add-needed -Xlinker --no-as-needed
Further, details regarding system are as follows:
cat /proc/version
Linux version 2.6.32.12-0.7-default (geeko@buildhost) (gcc version 4.3.4 [gcc-4_3-branch revision 152973] (SUSE Linux) ) #1 SMP 2010-05-20 11:14:20 +0200
icc --version
icc (ICC) 11.1 20100806 Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
lsb_release -a
LSB Version: core-2.0-noarch:core-3.2-noarch:core-4.0-noarch:core-2.0-x86_64:core-3.2-x86_64:core-4.0-x86_64:desktop-4.0-amd64:desktop-4.0-noarch:graphics-2.0-amd64:graphics-2.0-noarch:graphics-3.2-amd64:graphics-3.2-noarch:graphics-4.0-amd64:graphics-4.0-noarch Distributor ID: SUSE LINUX Description: SUSE Linux Enterprise Server 11 (x86_64) Release: 11 Codename: n/a
uname -m
x86_64
