We have a customer who is trying to use a single compiler suite across platforms, but the intel compiler is giving slower performance than the pgi compiler on the AMD processor. The current options used for the compiler are
O3 -g -xHost -fno-fnalias -fno-alias -sox -traceback -complex-limited-range
Is there a better set of generic options that should be used for the latest AMD processor?
I have checked the knowledge base and I could have missed a thread here, but none of these seem to address this issue very much. Any information is appreciated.
Quoting - draceswbell.net
Also is it possible to send a testcase?
Thank you,
Jennifer
If your code depends for performance or accuracy on performing operations in order specified by parentheses, you may find better results by adding -fp-model source .
The optimization performed by icc is more effective on barcelona and newer AMD CPUs; there is no choice specifically for older CPUs.
Thanks. This is in line with the option tests we tried. We will try to get a test case that shows the difference in performance, but this is proprietary code that is very large so it will take a while to reduce this to a small test case.
