Intel® C++ Compiler
7956 Discussions
Intel Compiler fails during final link (but g++ works)
oss_compiler
I was trying to build node.js with intel compiler. All files compile okay, but the final linking stage fails. Strangely, if I use g++ for final link, it still work. The error message isn't quite helpful either. I have tried changing optimization from O3 to O2 - but no difference
": internal error: ** The compiler has encountered an unexpected problem. ** Segmentation violation signal raised. ** Access violation or stack overflow. Please contact Intel Support for assistance. icpc: error #10014: problem during multi-file optimization compilation (code 4)
Appreciate any pointers ? Thanks!
Viet_H_Intel
Can you provide us your build log to take look?
Viet
oss_compiler
I have the final linker log attached. Is there a way to get extended log ? On a different topic, are there any flags I need to use to make ICC compatible with GCC. I have great difficulty compiling projects that just work with GCC.
Edit: I also added all.log which is the log of entire build.
Viet_H_Intel
What GCC version are you using?
can you try to replace icpc manually with g++, to see if it link successfully? Dont rebuild your project, just try to link with g++
icpc (replace icpc with g++) -pthread -rdynamic -m64 -Wl,--whole-archive,/home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/openssl/libopenssl.a -Wl,--no-whole-archive -Wl,-z,noexecstack -Wl,--whole-archive /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/v8/src/libv8_base.a -Wl,--no-whole-archive -pthread  -o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/node -Wl,--start-group /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/async-wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/cares_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/connection_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/connect_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/env.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/fs_event_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/handle_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/js_stream.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/module_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_api.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_buffer.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_config.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_constants.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_contextify.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_debug_options.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_file.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_http2.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_http_parser.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_main.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_os.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_platform.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_perf.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_serdes.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_url.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_util.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_v8.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_stat_watcher.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_watchdog.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_zlib.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_i18n.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/pipe_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/process_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/signal_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/spawn_sync.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/string_bytes.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/string_search.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/stream_base.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/stream_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/tcp_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/timer_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/tracing/agent.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/tracing/node_trace_buffer.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/tracing/node_trace_writer.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/tracing/trace_event.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/tty_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/udp_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/util.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/uv.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/gen/node_javascript.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/inspector_agent.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/inspector_io.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/inspector_js_api.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/inspector_socket.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/inspector_socket_server.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_crypto.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_crypto_bio.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/node_crypto_clienthello.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/tls_wrap.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/node/src/backtrace_posix.o /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/nghttp2/libnghttp2.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/v8/src/libv8_libplatform.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/tools/icu/libicui18n.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/openssl/libopenssl.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/zlib/libzlib.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/http_parser/libhttp_parser.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/cares/libcares.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/uv/libuv.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/v8/src/libv8_base.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/v8/src/libv8_libbase.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/v8/src/libv8_libsampler.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/tools/icu/libicuucx.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/tools/icu/libicudata.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/tools/icu/libicustubdata.a /home/ubuntu/cloudbin/node-v9.1.0.icc/out/Release/obj.target/deps/v8/src/libv8_snapshot.a -ldl -lrt -lm -Wl,--end-group
Viet
oss_compiler
Viet - Yes. replacing icpc with g++ does work (ofcourse, I need to link libirc and libimf). g++ version is 5.4.0
There are other issues with my other projects too. GCC works just fine - but there is some issue or other. For example, there is one involving builtins available in gcc, but not icc.
error: argument is incompatible with formal parameter return __builtin_mul_overflow(lhs, rhs, product);
Are there any best practises to make icc/icpc become gcc compatible ?
Viet_H_Intel
Is it possible to provide all of your objects and dependency libs so that we can reproduce the issue at our end?
_builtin_mul_overflow(...) is available in ICC as well. Seems like you have miss-matched between argument and parameter.
Viet
oss_compiler
Viet Yes - I can provide. Is there an email I can send those (it could be huge) ?
jimdempseyatthecove
icc with any optimization level enables by default multi-file interprocedural optimizations. Try disabling multi-file IPO (-no-ipo). If that works then try adding back intra-file interprocedural optimizations (-ip).
If that works then you can potentially compose your application into two parts, those that can have multi-file interprocedural optimizations, and those that cannot (you may need to place those that cannot into an .so or lib file).
Follow the advice given by Viet and determine the cause for the error.
Jim Dempsey
Viet_H_Intel
can you tar it up and attach here?
Hi Jim,
I don't think objects were built with -ipo as mentioned that it was able to link with g++. ipo objects are required to use icc to link.
Viet
oss_compiler
Jim - Thanks. Turning off ipo did help in getting a successful build. But adding back "-ip" gave the same error. I am actually okay to not use "-ip" (assuming the individual files are compiled with best flags - so final linking optimization may only offer incremental performance..I am guessing here though)
oss_compiler
Viet - Please see https://s3.amazonaws.com/icc_projects/icc_error.tar.gz for the entire tar bundle. It contains everything you would need. Thanks for taking a look.
Viet_H_Intel
Not sure what happened, but I couldn't be able to link
vahoang@orcsle147:/tmp$ sh vah_icc.sh
/tmp/vah/icc_errors/issue1_ipoissue/node-v9.1.0.icc/out/Release/obj.target/deps/nghttp2/libnghttp2.a: could not read symbols: Malformed archive
oss_compiler
Viet - Could you try rebuilding again ?
make clean
 ./configure
make CC=icc CXX=icpc -j35 [35 threads or whatever #of cores you have]
This will go through until the final link stage. The other easier option is for me to give access to my system so you can poke around. Let me know if it's preferable
Viet_H_Intel
For issue1: I saw the error if I rebuild it. I'll take me sometime to investigate though. I will let you know
For  issue2, I was able to compile. I didn't see it complained about builtin_mul_overflow(...)
vahoang@orcsle147:/tmp/vah/icc_errors/issue2_nobuildin$ sh vah.sh
vahoang@orcsle147:/tmp/vah/icc_errors/issue2_nobuildin$ ls -lt explain_cmd.o
-rw-r--r-- 1 vahoang ome 4184168 Nov 13 19:27 explain_cmd.o
vahoang@orcsle147:/tmp/vah/icc_errors/issue2_nobuildin$ cat vah.sh
icpc -o explain_cmd.o -c -std=c++14 -fno-omit-frame-pointer -fno-strict-aliasing -ggdb -pthread -fstack-protector-strong -fno-builtin -memcmp -fPIE -DPCRE_STATIC -DNDEBUG -D_FORTIFY_SOURCE=2 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_MATH_NO_LONG_DOUBLE_MATH_FUNCTIONS -Isrc/third_party/s2 -Isrc/third_party/pcre-8.41 -Isrc/third_party/boost-1.60.0 -Ibuild/opt -Isrc src/mongo/db/commands/explain_cmd.cpp -w -diag-disable:remark
Viet
oss_compiler
That's great to now. My ICC is as below. Are we using the same version ?
$ /opt/intel/compilers_and_libraries_2018.0.128/linux/bin/intel64/icc --version icc
(ICC) 18.0.0 20170811 Copyright (C) 1985-2017 Intel Corporation. All rights reserved.
I still get an error as attached.
Viet_H_Intel
Yes, I used the same compiler version because we only have one ICC 18.0 released version.
$ icc -V
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.0.128 Build 20170811
Not sure why you got the error, I tried on a few different machines, it compiled successfully. I got some warnings if I removed -w.
$ sh vah.sh
icpc: command line warning #10159: invalid argument for option '-m'
In file included from /nfs/pdx/disks/cts2/tools/gcc/gcc-5.3.0/bin/../include/c++/5.3.0/x86_64-unknown-linux-gnu/bits/os_defines.h(39),
                 from /nfs/pdx/disks/cts2/tools/gcc/gcc-5.3.0/bin/../include/c++/5.3.0/x86_64-unknown-linux-gnu/bits/c++config.h(482),
                 from /nfs/pdx/disks/cts2/tools/gcc/gcc-5.3.0/bin/../include/c++/5.3.0/new(39),
                 from src/third_party/boost-1.60.0/boost/optional/optional.hpp(20),
                 from src/third_party/boost-1.60.0/boost/optional.hpp(15),
                 from src/mongo/db/commands.h(31),
                 from src/mongo/db/commands/explain_cmd.cpp(31):
/usr/include/features.h(330): warning #1224: #warning directive: _FORTIFY_SOURCE requires compiling with optimization (-O)
  #  warning _FORTIFY_SOURCE requires compiling with optimization (-O)
In file included from src/mongo/db/dbmessage.h(37),
                 from src/mongo/db/query/canonical_query.h(33),
                 from src/mongo/db/query/explain.h(33),
                 from src/mongo/db/commands.h(43),
src/mongo/db/server_options.h(192): warning #858: type qualifier on return type is meaningless
          const bool isVersionInitialized() const {
src/mongo/db/server_options.h(200): warning #858: type qualifier on return type is meaningless
          const Version getVersion() const {
src/mongo/db/server_options.h(214): warning #858: type qualifier on return type is meaningless
          const bool isSchemaVersion36() {
src/mongo/bson/util/builder.h(292): warning #2196: routine is both "inline" and "noinline"
              grow_reallocate(minSize);
          detected during instantiation of "char *mongo::_BufBuilder<BufferAllocator>::grow(int) [with BufferAllocator=mongo::SharedBufferAllocator]" at line 138 of "src/mongo/bson/bsonobjbuilder.h"
oss_compiler
Something is wrong. So I added -M option to the command and it spits out the dependencies as below. Anything getting messed up in the includes may be ? I am clueless as well.
explain_cmd.o: src/mongo/db/commands/explain_cmd.cpp /usr/include/stdc-predef.h \
 src/mongo/platform/basic.h src/mongo/db/commands.h \
 src/third_party/boost-1.60.0/boost/optional.hpp \
 src/third_party/boost-1.60.0/boost/optional/optional.hpp /usr/include/c++/5/new \
 /usr/include/x86_64-linux-gnu/c++/5/bits/c++config.h \
 /usr/include/x86_64-linux-gnu/c++/5/bits/os_defines.h /usr/include/features.h \
[--Edited out rest to reduce clutter----]
oss_compiler
Actually adding -H gives the include path as below
. /usr/include/stdc-predef.h
. src/mongo/platform/basic.h
. src/mongo/db/commands.h
.. src/third_party/boost-1.60.0/boost/optional.hpp
... src/third_party/boost-1.60.0/boost/optional/optional.hpp
jimdempseyatthecove
I notice that you are using boost. Boost templates predate many of the newer std:: templates, in particular std::enable_if, and those often use within enable_if to qualify expansion. IOW, if you omit std:: or boost::, you may end up with the wrong (unintended) template.
Due to the error seemingly related to return type, and/or argument type, you may have template expansion issues.
I suggest you examine all occurrences of enable_if to assure it, and enclosed templates, are properly scoped.
Jim Dempsey
oss_compiler
Jim - Strangely, the build does work for Viet without any changes. We are using the same icc compiler version too.
jimdempseyatthecove
Then something is different with the build.
Different amount of RAM
Different (e.g. ulimit) stack setting
Different ISA, or number of cores/logical processors
Different "random" junk (uninitialized data and/or buffer overruns)
Different behavior using deleted pointer
These would all be latent bugs in the compiler. Look closer at what differs to try to get Viet's system to fail.
Jim Dempsey
