I am working on a high performance application where I would prefer to use Intel compiler for computations but the main application is itself in COM using Microsoft Compiler. I have two roadblocks in this which I am posing as question. Any pointers and help is appreciated for this
- Is it possible to compiler high performance part of the application in Intel Compiler as a lib or dll and load it into an application using Microsoft compiler using Dynamic or static linking? Are there any pitfalls to the approach which I need to be aware of
- What is the level of support Intel compiler offers for Microsoft COM? We have a part of potential code which is written in COM as service. Is it possible to compile this under Intel Compiler or should we isolate COM to Microsoft Compiler. I am aware that Fortran compiler supports COM but I am not aware of the level of support on C++. As well is it possible consume COM in Intel C++ as a client using CoInitializeEx?
- What is the level of support for Microsoft ATL in Intel C++ Compiler?
Thanks for the support and clarification.
Sai
Hello Sai,
The answer to all your questions are yes.
If you create your COM DLL with Visual Studio, the dll can be built with Intel C++ as well. Same for ATL. Only limitation is that Intel C++ compiler does not support /clr.
Let me know if you have more questions.
thanks,
Jennifer
I mean if the project created with Visual Studio does not contain CLR, it can be compiled with Intel C++. It should be 100% compatible without /clr.
Jennifer
