$ cat main.x.cpp #include <iostream> #include <experimental/filesystem> namespace fs = std::experimental::filesystem; int main() { std::cout << "Current path is " << fs::current_path() << '\n'; } $ icpc main.x.cpp -lstdc++fs -std=c++14 # Works! $ icpc main.x.cpp -lstdc++fs -std=c++14 -g # Doesn't work /spare/scratch/icpcNgdXiG.o: In function `std::basic_string<char, std::char_traits<char>, std::allocator<char> > std::experimental::filesystem::v1::path::string<char, std::char_traits<char>, std::allocator<char> >(std::allocator<char> const&) const': /spare/scratch/tmp-e31ZpjU-infra/gcc/5.4.0/include/c++/5.4.0/experimental/fs_path.h:822: undefined reference to `std::codecvt_utf8<char, 1114111ul, (std::codecvt_mode)0>::codecvt_utf8(unsigned long)' /spare/scratch/tmp-e31ZpjU-infra/gcc/5.4.0/include/c++/5.4.0/experimental/fs_path.h:822: undefined reference to `std::codecvt_utf8<char, 1114111ul, (std::codecvt_mode)0>::~codecvt_utf8()' /spare/scratch/tmp-e31ZpjU-infra/gcc/5.4.0/include/c++/5.4.0/experimental/fs_path.h:825: undefined reference to `std::codecvt_utf8<char, 1114111ul, (std::codecvt_mode)0>::~codecvt_utf8()' $ icpc main.x.cpp -lstdc++fs -std=c++14 -g -mGLOB_opt_level=1 # Works!
This has been tested with Intel compilers 16 to 19 and the behavior is same.
- Tags:
- Bug
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
It looks like a bug. We are able to reproduce this error. We will escalate this issue to the concerned team.
Rahul
I've opened a case with the compiler Developer. Case# is CMPLRIL0-32514. Thanks,
Can you use one of these workarounds?
$ icpc t3.cpp -std=c++14 -lstdc++fs -g -O1
$ icpc t3.cpp -std=c++14 -lstdc++fs -g -O2
$ icpc t3.cpp -std=c++14 -lstdc++fs -g -O3
$ icpx t3.cpp -std=c++14 -lstdc++fs -g
Hi Nehal,
Could you please let us know if your issue is resolved or not?
Arpita
Hi Nehal,
We are closing this thread as we haven't heard back from you. We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only
Prasanth
