Intel® C++ Compiler
7783 Discussions
Intel Compiler using libs from gcc 4.5.2
zvivered
I'm using Intel Compiler 11.1/064
The intel compiler uses include files and libs from gcc 4.3.2 created with the crosstool-ng project.
I'm using the swithc -gcc-version=430 in compilation
Now I want to use gcc 4.5.2
Should this work ?
Zvika
TimP
Black Belt
A gcc minor version update should not affect compatibility with icc/icpc. For major version updates in gcc, you would need a more up to date icc (13.x for icpc 4.7).
