Intel® C++ Compiler
7957 Discussions
Intel Composer XE's C++ compiler does not integrate with Visual studio 2010
Giap_Huynh
We installed Intel Composer XE suites that included Fortran and C++ compiler and both are supposed to integrate with our Visual studio 2010. However, only Fortran compiler shows up in Visual studio and not C++. We tried to installed separately with C++ package only but it still doesn't show up. What happened and how do we get it to work on Visual Studio 2010?
Hubert_H_Intel
Giap,
The Fortran integration is different than the C++ Compiler integration into Visual Studio 2010. For C++ you can switch forth and back compilers via the project properties > Intel Composer XE > Use Visual C++ / Use Intel C++.
Please extract one of the sample solutions from the C++ Composer XE installation, for example C:\Program Files (x86)\Intel\Composer XE 2013 SP1\Samples\en_US\C++\NQueens.zip\ and load the solutions (.sln) file into Visual Studio.
Right-click on a project, e.g. nq-cilk > Intel Composer XE <version> > Use Intel C++. If the Intel Composer XE menu item isn't there you may not have installed the Visual Studio 2010 integration.
Regards, Hubert.
